-6 or -8 to carb...?? - Yellow Bullet Forums
Old 05-19-2009, 12:15 AM   #1
SNYPER
Member
Pullin gears
SNYPER's Avatar
Default -6 or -8 to carb...??
I am running a 900cfm C&S dual needle and seat carb and was wondering what everyone ran for feed to the carb from the regulator? I run two 15 gal tanks as this is in my boat.
My fuel system is...
-10 feeds off each tank to a Y block with a -12 feed to an aeromotive eliminator pump
-10 feed to 13224 regulator
-10 return to both tanks from another Y block
Just not sure if I should go with a -6 or a -8 to the carb, I was thinking -8 as it cant hurt.
Thanks guys!!!
Travis
Whipple Motorsports Speed and Custom
Spokane Wa- 509-926-5350
Kreative Koncepts Welding and Fabrication LLC
Spokane Wa- 509-263-1565
SNYPER is offline   Reply With Quote
Old 05-19-2009, 12:13 PM   #2
Honk if parts fall off
Drag Week Survivor
Default Re: -6 or -8 to carb...??
-6 would work, but like you said -8 can't hurt.
Honk if parts fall off is offline   Reply With Quote
Old 05-19-2009, 11:43 PM   #3
mikee
Keepn my pimp hand strong
mikee's Avatar
they say not to run a -8 plus you could run into clearance issues on rear accelerator pump.Have you ever taken the bowl apart and looked at the diameter hole feeding into it?You could actually run a -4 ,the -8 is just holding fuel at the inlet heating the fuel as it waits to enter the bowl.
mikee is offline   Reply With Quote
Old 05-20-2009, 12:06 AM   #4
BRIANS02TA
Member
Pullin gears
BRIANS02TA's Avatar
i used 8 an.with the duel n/s bowls i have u can use a 6 and be fine. i have no pump interference on mine.
head floor sweaper at sherwood performance.
68 chevelle
BRIANS02TA is offline   Reply With Quote
Resources saved on this page: MySQL 2.41%
