#1 |
Has anyone seen any performance difference in reducing the exhaust outlet diameter on a large single ?
I run a Precision 101mm with a steel 5 inch exhaust. I plan on building a all aluminum exhaust system to reduce weight. I was thinking of reducing the diameter from the 5 inch to 4 inch, but I dont want to hurt performance. |
#2 | |
Quote:
Dan Saitz www.hyperformanceracing.com Aluminum, Stainless, Mild Steel Tubing & Bends FAST, BS3, Precision Turbo, MSD, Aeromotive, JGS, TCI, Comp Cams |
#3 | |
Member
Pullin gears
Quote:
Ideally you want to run 1.25 X turbine exducer diameter. Not always possible, but its nice if you can. I don't think you will hurt performance much...all depends on the length.
FI-Engineering.com 1-(256)-796-1230 1-(256)-658-5798 Authorized Distributor/Dealer and builder of: Garrett Borg Warner Holset Turbonetics Precision Turbo Mitsubishi Rajay IHI |
#4 |
What is considered too long? I have mine dumped behind the front tire.
#5 |
Member
Pullin gears
The 4" will definately take up less room.
TubingJon.com 517-403-1914 |
#6 |
Member
Pullin gears
put a pressure sensor in the exhaust and see where your at.
![]() NLR Systems WD-- Bullseye Power Turbo's WD-- Precision Turbo WD--Injector Dynamics Dealer **new 2000cc injectors!!**---- PM for pricing and information |
#7 |
How much do you reckon these downpipes are restricting me then Joe?
world's fastest radial pump gas car 7.67 and 190.4mph on 93 Shell V power and 315 MT drag radials.... 7.41 and 197.6 on VP Q16 and MT ET streets. Turning it into a street legal turbo pro mod for 2011. A huge thanks to my US sponsors: Mickey Thompson tires, Neal Chance racing converters, RFD,Total Seal, VP fuels, DEI, Injector Dynamics, Fast Motorsports,VFN fibreglass, Turbowerx and Wilson manifolds. Andy Frost race transmissions. www.redvictor1racing.co.uk |
#8 |
Member
Pullin gears
is that an electromotive DFU i see?
i personally have not gotten around to doing any testing on that stuff as most of the cars we work on we can fit a 4" exhaust/downpipe pretty easily. my buddy works at a shop with an engine dyno and have seen 25-26psi pressure in the downpipe on a 3" exhaust. ive done a lot of 2.5" to 3" before and after stuff, and its typically 60-100 horsepower gain on a turbo in the 61mm range. again its all high reving 4 cylinder stuff though.
#9 |
Member
Pullin gears
this is the only thing i had on this computer
![]() if i remember correctly this was a 61mm, 2.2 motor, 8500 rpm, 2.5" before, 3" after. spring pressure no boost controller even installed. roughly 10-11psi. no adjustments to the tune, hence the big dip on the low end.
#10 | |
Quote:
I have 44psi of back pressure at 26psi of boost and bigger housings have made no difference whatsoever. I'm convinced that the ex flow out of the housing cannot get out fast enough.. Here's a vid from the dyno 3 years ago.Look how the heat goes from the housing.I think the flow is choking from the wheel back.. http://videos.streetfire.net/video/E...R-by_39705.htm
#11 |
Pre-Staged
#12 |
Pre-Staged
------------------------------------------------ Just trying to go fast...Driving a 9 second BMW with A/C and leather seats. www.bmwturbo328.com |
#13 |
Member
Pullin gears
We have a 4.5" aluminum on ours. Approx 5-6'
Needing to find wheels... apparently |
| Thread Tools | |
| Display Modes | |
