First time 4 link setup? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 05-08-2009, 10:38 PM   #1
jerryl
Spooled up
Default First time 4 link setup?
I've have no experience setting up a 4link car.Heres what i'm working on.65 chevy II,SBC 610hp,turbo 350 with a brake,456 gear,31'' tires,no idea what it weighs,Hoping for mid 10s. If I measured right the intersect point is about 51" out. Im not sure how to measure how high up.I'm also confused on setting the pinion angle.I don't have a drive shaft yet so i measured the angle at the balancer. It's 3 degrees down so the pinion should be 2 degrees up?
[IMG]http://i122.photobucket.com/albums/o252/jdss4/IMG_3986.jpg
jerryl is offline   Reply With Quote
Old 05-08-2009, 10:40 PM   #2
jerryl
Spooled up
Default Re: First time 4 link setup?
hope this works
Old 05-08-2009, 10:46 PM   #3
MattG
MattG's Avatar
Invest in some 4link software. I have always used 4link wizard and it works great. You give it a bunch of measurements and it shows you all your available instant centres and how to set the bars.
MattG is offline   Reply With Quote
Old 05-08-2009, 11:58 PM   #4
race9899
race9899's Avatar
Here is a quick set up if you can get the bars to it...
Lower bar level..
Front upper bar in a hole 6.5" to 7" above lower
Rear upper 11" to 12" above lower...
If your Lower 4 link bar is 6" up and you use 12" and 7" as your spreads that will be approximately 53 inches out and 6" up
With the lower bar level you intersect height will be whatever the height of the bar is...
If you are going to use your car as a driver, you make the pinion angle match the engine transmission angle..
If you are going to be racing it, you will need a Drive shaft and will set the pinion to give 2-3 degrees of Pinion Nose Down angle..
If the Driveshaft is level then you will point the pinion down 2-3 Degrees.. If the Driveshaft runs down to the rearend 1 degree you will point the pinion down 1-2 degrees..
www.makotenfive.com
_________________________________________________
Holloway Race Cars
Broken Arrow Oklahoma
race9899 is offline   Reply With Quote
Old 05-09-2009, 11:29 AM   #5
Techguy
Spooled up
Techguy's Avatar
Quote:
Originally Posted by jerryl View Post
hope this works
from your above settings, & what you described.. I'd go a little
shorter & higher... raise the front bottom hole 1 & see how it likes that..
Mike Weddle
Senior Sales Technician
Chris Alston's Chassisworks
800-722-2269 xt 250
www.cachassisworks.com
Techguy is offline   Reply With Quote
Old 05-09-2009, 05:26 PM   #6
BillyShope
Member
Pullin gears
BillyShope's Avatar
It lacks the pretty pictures of the purchased software, but Page 13 of my site provides the IC location and percent antisquat and it's free.
http://home.earthlink.net/~whshope
over 150,000 page views
BillyShope is offline   Reply With Quote
Old 05-10-2009, 09:58 AM   #7
jerryl
Spooled up
Thanks for the link Bill.Looks like it would work great if I could figure out were to measure from.
"The horizontal and vertical dimensions are related to the rear tire patch."
What??
Old 05-10-2009, 04:50 PM   #8
BillyShope
Member
Pullin gears
BillyShope's Avatar
What??
I've had quite a few ask the same question. Vertical distance is from the shop floor. Horizontal distance is from the rear axle centerline.
Or, in the jargon of an engineer, the origin of the coordinate system is located at the rear tire patch.
I guess I'll have to go in and clarify. In fact, I'll go and do it as soon as I post this.
Old 05-10-2009, 04:58 PM   #9
BillyShope
Member
Pullin gears
BillyShope's Avatar
What??
It's been fixed.
Old 05-10-2009, 06:20 PM   #10
jerryl
Spooled up
Thanks for explaining that.I get it now.Now if I could figure out my center of gravity.
Old 05-10-2009, 06:25 PM   #11
jerryl
Spooled up
oops ,I just saw the answer to my last question is on page 31.
Thanks Bill.
Old 05-10-2009, 07:28 PM   #12
BillyShope
Member
Pullin gears
BillyShope's Avatar
As you play with the spreadsheet, you'll see that the CG height estimate can be a bit off and the results don't change all that much. Just make a reasonable estimate.
Old 06-22-2009, 08:21 PM   #13
Bob13200
Burnout box
There appears to be a multitude of settings that will achieve the same IC, so when starting out which would be the preferred locations to use in the axle brackets. Does it even matter?
Bob13200 is offline   Reply With Quote
Old 06-22-2009, 09:01 PM   #14
BillyShope
Member
Pullin gears
BillyShope's Avatar
Quote:
One thing to remember: The greater the spread (vertical distance) between the upper and lower link, the lighter the loads to be carried by the links, Heims, etc.
http://www.racetec.cc/shope
Resources saved on this page: MySQL 1.00%
