406 SBC what solid roller cam suggestions - Yellow Bullet Forums
Old 05-08-2009, 06:40 AM   #1
Aussie400
Aussie400's Avatar
Default 406 SBC what solid roller cam suggestions
Scat H Beam 5.7 Rods
Eagle Steel Crank
11.5 Comp
Afr 227 Cnc Compertion Heads ( out of the box)
Brodix 1002 hvh Manifold
950 Hp Holley
Harland sharp 1.6 .50 offset rockers 5/16 pushrods
Crower or comp cams Roller lifter (not sure yet)
Australian BP 98 unleaded octane fuel
How much HP from this combo ? with the right cam ?
Any help would be apprecatted
Greg
thanks Greg
Aussie400 is offline   Reply With Quote
Old 05-08-2009, 07:05 AM   #2
johnnygohard
Spooled up
Default Re: 406 SBC what solid roller cam suggestions
lunati 276/284 108 ,sounds like a very simillar combo to mick varneys old hatch it made 650 crank hp and 9.70s
johnnygohard is offline   Reply With Quote
Old 05-08-2009, 08:23 AM   #3
Horndog
http://www.lunatipower.com/Product.aspx?id=1810&gid=250
This is the Lunati roller I have in my 406. It is a small base circle cam (.900"). I have the Lunati Pro-Mod rods (I-beam) in mine. You will want to check rod/cam clearance with those Scat rods.
The cam is very similar to the one above but the LSA is 106, not 108. Maybe a typo on johnny's part.
It is very easy on the valvetrain. I run T&D shaft rockers on Brodix Track 1 heads.
I'd bump up the compression some if you can. I see you're running pump swill with a 98 octane rating. I'd think that would support 12.1 to 12.5:1 comp.
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
Horndog is offline   Reply With Quote
Old 05-08-2009, 09:40 AM   #4
MCEcomp
Member
Pullin gears
MCEcomp's Avatar
If your stuck with 11.5:1 comp something like a crane R-270/420-s6 would be a better choice
MCEcomp is offline   Reply With Quote
Old 05-08-2009, 09:54 PM   #5
trmnatr
Butch
trmnatr's Avatar
Quote:
276/284 @.050" on a 106 lobe center with mid 600 lift for street
For race an agressive Comp or Crane (which is not in business now) so the one i like from Comp is this,,
HXL / RZ lobes
307/317 @.020"
278/284 @.050"
201/197 @.200"
.726"/.704" lift
106 lobe seperation, set the intake centerline @ 106 too
On 11.5:1 on pump gas you should be able to push 610hp,,
Go up to 13:1-14:1 and i would hope the engine would put out 650-680hp
You should run a Manley NexTek or Erson FSP 1.640" O.D springs on this assuming they will fit your rockers,,, If not PAC 1226
trmnatr is offline   Reply With Quote
Old 05-09-2009, 10:18 AM   #6
Aussie400
Aussie400's Avatar
Thanks Guys
Resources saved on this page: MySQL 2.35%
