What kind of ET should I expect? Roughly - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 05-03-2009, 10:38 AM   #1
"Little Red Wagon68"
Pre-Staged
"Little Red Wagon68"'s Avatar
Question What kind of ET should I expect? Roughly
All right so if I have a "SBC" making 900hp NA at the fly wheel in a car weighing 3060#'s with the driver. What kind of ET's should I expect in the 1/8? Roughly.
Here is what my set up is......Motor and car wise.
1965 Nova wagon
PG tranny with a 8 1/2 converter(stall probably in the 5800+range)with a T-brake Pro tree
Rear tire's are 32x14's Good Year's
Ford 9" with 4.88 gear's and a spool. Gear's might change if needed
Ladder bar's.
Real racer's drive straight to the finish l!ine while other's drive in circles looking for it
"Little Red Wagon68" is offline   Reply With Quote
Old 05-03-2009, 11:07 AM   #2
dalacheax1
The Warbird
dalacheax1's Avatar
Default Re: What kind of ET should I expect? Roughly
High 5's to Low 6.'s
I'm making 875hp at the flywheel, 688rwhp and I run 6.03 to 6.05 with 4.56/31" tire at 2975lb
dalacheax1 is offline   Reply With Quote
Old 05-03-2009, 11:21 AM   #3
4 BOLT
4 BOLT's Avatar
Try this software http://www.virtualengine2000.com/95874625841267938.htm
calibrate it with one of your old time slip and you should be right on the money.
4 BOLT is offline   Reply With Quote
Old 05-03-2009, 12:01 PM   #4
Pre-Staged
I would love to calibrate it with one of my old time slip's but....................My old time slip's were with my old motor combo. And I was running a 427sbc that made 630hp at the fly wheel. And my best was a 6.39 at 108mph. But I will take a look at the web site any way. Thank's for the info
Old 05-03-2009, 12:18 PM   #5
qwiknotch
ProStock Jackstand Winner
qwiknotch's Avatar
damn, you lost almost 200hp to the wheels? what trans/converter do you have?
qwiknotch is offline   Reply With Quote
Old 05-03-2009, 12:50 PM   #6
Pre-Staged
Quote:
Kind of what I was thinking.
Old 05-03-2009, 10:33 PM   #7
purple5568
Launchin
purple5568's Avatar
I ran a 3250# car with 922 FWHP, 33x15x15 tire 5.14 gear and a lenco it went high 5.80s to low 5.90s in the summer at 116 to 118 mph this was in 1997and 1998.
purple5568 is offline   Reply With Quote
Old 05-03-2009, 11:26 PM   #8
punisher#1
punisher#1's Avatar
@ 3100lbs and 920 fwhp my car ran 5.85 with a 5800 rpm 8-inch converter and 4.10 gears on a 29.5x10.5 tire. this was in excellent conditions. air density was -200ft.
the world's fastest pontiac powered ford fairmont.
punisher#1 is offline   Reply With Quote
Old 05-04-2009, 12:28 AM   #9
4 BOLT
4 BOLT's Avatar
Must of had a TH400 Trans.
Old 05-04-2009, 03:14 AM   #10
tenfiveracer
In the Beams.
tenfiveracer's Avatar
5.90 @ 130 mph range
tenfiveracer is offline   Reply With Quote
Old 05-04-2009, 07:56 AM   #11
dalacheax1
The Warbird
dalacheax1's Avatar
875hp was uncorrected, 688 was actual corrected rwhp.We figure the actual corrected flywheel hp at around 830 to 860 roughly.We only had the motor only flywheel hp.Added a 175hp plate kit later.
Old 05-04-2009, 11:14 AM   #12
feetfirst
feetfirst's Avatar
You have SERIOUS hp power issues.............I run 6.00's with 560 rear wheel hp at the same weight......2000 DA.....
This 25.5 chromoly-stock suspension car is FORSALE!!!
feetfirst is offline   Reply With Quote
Old 05-04-2009, 11:17 AM   #13
feetfirst
feetfirst's Avatar
1965 Nova wagon
Ladder bar's.
If it dont run 5.60's @ 122-124 you are having problems........
Old 05-04-2009, 11:57 AM   #14
dalacheax1
The Warbird
dalacheax1's Avatar
Quote:
I think the air MIGHT be a LITTLE bit cooler with a LITTLE less humidity where you live.I live in the deep south.And some 4.88 gears would of put me in the 5.'s but I'm putting 5.43"s in in 2 weeks.
Old 05-04-2009, 12:08 PM   #15
feetfirst
feetfirst's Avatar
Oh okay........do you know what DA is?
