problem with trans break leaking!!! - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 04-29-2009, 10:01 PM   #1
$THATGUY$37
Burnout box
Default problem with trans break leaking!!!
im haveing problems geting my trans break to seal iv used diff washers and seals and it still leaks! any ideas??
$THATGUY$37 is offline   Reply With Quote
Old 04-30-2009, 08:19 AM   #2
jonesy1
jonesy1's Avatar
Default Re: problem with trans break leaking!!!
Are you talking about the solenoid????
4.27 @ 170 MPH
6.67 @ 210 MPH on 2 guns with my OLD motor. The new one is going to be a different story.
Thanks to:
Davis Race Cars
Abruzzi Transmission & Converters
Dave Bayus
Hyatt Racing Services
L and M Motorsports
Buck Racing Engines
jonesy1 is offline   Reply With Quote
Old 04-30-2009, 09:02 AM   #3
Real McCoy
Real McCoy's Avatar
I have had the solenoid seals leak. My trans guy and I couldn't find a source to buy new ones either. I have 3 solenoids all from the same manufacturer and each has a different type seal. I ended up using a seal from a solenoid what was damaged beyond repair to fix my spare that dripped. RM
Real McCoy is offline   Reply With Quote
Old 04-30-2009, 12:45 PM   #4
Get dustd
Spooled up
scotch bright the sealing surface and clean it and check for sharp edges and install one with fresh orings
Get dustd is offline   Reply With Quote
Old 04-30-2009, 01:51 PM   #5
BIG CAT
SASQUATCH RACE TEAM
BIG CAT's Avatar
get a oring assortment. make sure it is compatible with hydraulic fluid.
my kit is a buna n material. but nitril should work also.
BIG CAT is offline   Reply With Quote
Old 04-30-2009, 10:30 PM   #6
fastman-99
fastman-99's Avatar
i have never seen a TB solenoid that didnt leak or seep to some extent. I just assumed it was normal. I have never talked to a fellow racer that didnt have the same problem either. I suppose seeping is different then leaking though!!
first ever ride of the month on www.s10dragracer.com
http://www.getphpbb.com/phpbb/viewfo...ecacc38067a2b8
fastman-99 is offline   Reply With Quote
Old 05-20-2014, 02:23 PM   #7
FLYNHIGH
Member
Pullin gears
Never had one leak. By the way its spelled BRAKE!
FLYNHIGH is offline   Reply With Quote
Old 05-21-2014, 02:31 PM   #8
hhott71
hhott71's Avatar
Quote:
Trans "break" is leaking, well DUH weld up the BREAK!
71 Camaro 355 NA
11.1650 @ 119.64
hhott71 is offline   Reply With Quote
Old 05-21-2014, 08:55 PM   #9
SQ329L
SQ329L's Avatar
Garage
TCI brake and paper gasket = no leaks for me........as long as I remember to tighten the solenoid when im putting the trans together........Couldn't figure out why my lights were all over the place until I noticed the leak.
SQ329L is offline   Reply With Quote
Old 05-21-2014, 09:10 PM   #10
trmnatr
Butch
trmnatr's Avatar
ati internal solenoid doesn't leak, griner too
my jw brake doesn't leak
trmnatr is offline   Reply With Quote
Old 01-21-2016, 05:14 PM   #11
flyingdutchmanfc
El-conquistador, sir
flyingdutchmanfc's Avatar
My guy takes the solenoid apart, there's a n oring about 1/2 inch diameter. He machines the ledge it sits on to hold 2 orings.
flyingdutchmanfc is offline   Reply With Quote
