g body, anti roll bars pics??? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 04-22-2009, 11:51 PM   #1
onefastermonte85
Member
Pullin gears
onefastermonte85's Avatar
Default g body, anti roll bars pics???
Anyone have some pics of their anti roll bars?
I want to see if i had mine mounted in the appropriate place.
The one side broke off and i have to cut it out and put a new one in.
heres a pic of where it broke
Go fast or go home.
onefastermonte85 is offline   Reply With Quote
Old 04-23-2009, 09:11 AM   #2
Louie L
Louie L's Avatar
Default Re: g body, anti roll bars pics???
Thats where mine is also. You could run into issues if the car is very low. If its normal height or slightly lowered you will be just fine.
Louie L is offline   Reply With Quote
Old 04-23-2009, 01:30 PM   #3
onefastermonte85
Member
Pullin gears
the car is at the standard height.
I was thinking of just getting a new metal tube and welding it back together. Sucks that something always has to break especially when your not even racing.
Go fast or go home.
Old 04-23-2009, 02:30 PM   #4
Louie L
Louie L's Avatar
Cant you just re weld it back in the spot and guset it.
Old 04-23-2009, 03:17 PM   #5
Louie L
Louie L's Avatar
What I meant to say was... cant you fix it with out removal? Looks like you could reweld the crack and guset the bottom for strenght.
Old 04-23-2009, 03:45 PM   #6
onefastermonte85
Member
Pullin gears
i was thinking i could until i looked at the tube, the back half is missing a section. Must of broke off and that piece of metal fell off. I was thinking of just cutting that area off pulling out the inner framing of it Grind that bad area all down, put a new piece of metal onto the framing and mount it back up. Its tough to write what i'm thinking but i think it could work.
Go fast or go home.
Old 04-23-2009, 06:12 PM   #7
blasttime
blasttime's Avatar
On my A body roll bar tubeing behind rear axle to both sides off frame then mount antia roll bar to it. Much easier Bob
blasttime is offline   Reply With Quote
Old 04-23-2009, 09:47 PM   #8
JeffMcKC
JeffMcKC's Avatar
Mine is welded on the ends then a stub off the frame to it in the middle to keep it from twisting.
I would have to ask what the hell is flexing there with the strap you have also welded to it the ARB is not a brace
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 04-23-2009, 11:13 PM   #9
onefastermonte85
Member
Pullin gears
i didn't weld it. this guy from youngstown ohio welded it up.
i figured that brace would support it well.
jeff can you post photo's of yours.
Go fast or go home.
Old 04-23-2009, 11:25 PM   #10
unholy1
unholy1's Avatar
I got one of these:
"When plunder becomes a way of life for a group of men living together in society, they create for themselves in the course of time a legal system that authorizes it and a moral code that glorifies it." -- FREDERIC BASTIAT
1979 Malibu - Steve Morris 382 SBC, F-1 Procharger, Noribilt A/W intercooler, 295 MT Street ET Radial - Best 9.14 @ 147 with beans left in her at 3300 lbs!
<img src=http://i264.photobucket.com/albums/ii189/unholy1racing/GRAINBELT.jpg border=0 alt= />
unholy1 is offline   Reply With Quote
Old 04-23-2009, 11:44 PM   #11
Olds80Six
Burnout box
BBO th400 12 Bolt
Olds80Six is offline   Reply With Quote
Old 04-24-2009, 07:02 AM   #12
JeffMcKC
JeffMcKC's Avatar
I will see if I can take one of it
TRZ Dealer
Old 04-24-2009, 09:01 AM   #13
onefastermonte85
Member
Pullin gears
unholy.
That looks like a simple setup, but its quite low to the ground. Is it as effective as the ones frame mounted??
Go fast or go home.
Old 04-24-2009, 09:21 AM   #14
Louie L
Louie L's Avatar
Thats the HRParts set up. It is very effective and ground clearance will depend on tire height. Lots of very Fast turbo regals with that set up out there.
Old 04-24-2009, 10:59 AM   #15
unholy1
unholy1's Avatar
Quote:
Originally Posted by onefastermonte85 View Post
unholy.
It's an HRParts N' Stuff anti-roll. Never had a clearance problem with it. it looks lower than it actually is. I can still get a floor jack under it. It's gone 9.23 so far launching dead-level.
As far as how low he car sits, here are a few pics with a 295 DR:
Resources saved on this page: MySQL 1.03%
