moroso.com;
Go Back   Yellow Bullet Forums > Technical Section > Rearends - Randy's Ring and Pinion
Old 04-06-2009, 05:04 PM   #1
Anthony Taddie
Member
Pullin gears
Anthony Taddie's Avatar
Thumbs down anyone broke a moser axle?
never thought mine would have broke?? waste of 400 bucks
Anthony Taddie is offline   Reply With Quote
Old 04-06-2009, 05:24 PM   #2
y2khawk
Spooled up
y2khawk's Avatar
Default Re: anyone broke a moser axle?
yep, tire shake is a bitch!
harlan
I keep gettin' older, they stay the same age
y2khawk is offline   Reply With Quote
Old 04-07-2009, 12:24 PM   #3
PONYEATER
Faster then Thor
PONYEATER's Avatar
Gun drilled or solid? I have seen a lot more gun drilled axles fail then solid ones in the higher HP applications. I am not a fan of gun drilling axles for this reason.
Arron
Randy's Ring & Pinion
800-347-1188 ext5579
PONYEATER is offline   Reply With Quote
Old 04-07-2009, 07:21 PM   #4
Anthony Taddie
Member
Pullin gears
I would have thought something else would break before the axel? Definatly not a high horsepower car.
Old 04-07-2009, 07:38 PM   #5
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
What kinda of power/weight/et's? If you wanna share that is......
I wanted to gun drill my 35 spline Mosers but have been leary of doing this for just the reason you took pictures of.
Mike Beck is offline   Reply With Quote
Old 04-07-2009, 07:45 PM   #6
ProGSX
Non Member
ProGSX's Avatar
Moser axles are garbage.
Jeff
Photo by http://photosbyjim.smugmug.com/
ProGSX is offline   Reply With Quote
Old 04-07-2009, 09:37 PM   #7
PONYEATER
Faster then Thor
PONYEATER's Avatar
Quote:
I have seen everyone's stuff break being in the drivetrain industry for a number of years. Rearends are the last thing upgraded in any drag car. Most guys don't think twice about upgrading from a 540 to a 598 or bigger and not thinking they need to upgrade center sections or axles. I am not defending any company I am just saying anything is breakable by ANY manufacturer: strange, dutchman, Moser, Mark Williams, Yukon, Sommers Brothers etc....
Arron
Old 04-07-2009, 09:39 PM   #8
PONYEATER
Faster then Thor
PONYEATER's Avatar
Quote:
What is that side gear for? mini spool? detroit?
Arron
Old 04-07-2009, 10:54 PM   #9
levers
Member
Pullin gears
levers's Avatar
how old were the axels
levers is offline   Reply With Quote
Old 04-07-2009, 11:47 PM   #10
94-6spd
Member
Pullin gears
94-6spd's Avatar
I have a moser 9" and I've broken the studs off the the pass. side before. Haven't broken the axle itself though.
94-6spd is offline   Reply With Quote
Old 04-08-2009, 12:44 AM   #11
Chuck u Farley M.D.
SeņorMiembro Grande penga
Chuck u Farley M.D.'s Avatar
Never had a issue with Moser or Strange.
Chuck u Farley M.D. is offline   Reply With Quote
Old 04-08-2009, 01:00 AM   #12
stanginthe11s
Spooled up
ive seen them all break, most of the time a broken axle is an indication of another problem. most aftermarket parts are held to tighter tolerances so theyre less forgiving when something isnt right such as an axle tube or end being off a little which puts load on the splines and bearings which is why you see alot of axles breaking at the tube end or splines. then theres tire shake which sucks and of course wrong selection of axle and over powering it.
just call moser, they should cover it for you.
stanginthe11s is offline   Reply With Quote
Old 04-08-2009, 07:31 AM   #13
ProGSX
Non Member
ProGSX's Avatar
I have seen them all break too, but none more than Moser.
Jeff
Old 04-08-2009, 08:17 AM   #14
Pitbull
Trouble Maker, So Im told
Pitbull's Avatar
x2 , I dont sell Moser never will.
Dealer for Carnivore Performance
www.gotsqueeze.com
TeamZ Suspension
Probe Industries
PA Racing Suspension
1989 25.5 Coupe roller for sale PM for details
True Street Sponsor 2006
Proud Sponsor of OSCA Pro Stock class 2009
11.90 Index Sponsor 2010
Pitbull is offline   Reply With Quote
Old 04-08-2009, 08:56 AM   #15
Scottyk
Member
Pullin gears
In their defense there is alot more mosier axles out there than any other brand I would assume so its only natural that more of those would fail.
Scottyk is offline   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
