8.75 Mopar rears? - Page 4 - Yellow Bullet Forums
Old 02-28-2013, 08:05 PM   #46
tomslik
tomslik's Avatar
Default Re: 8.75 Mopar rears?
here's what i've been told (by some stock-class racers) 741's are the least desirable no aftermarket support...
489 and 742 are about equal in strength but the 489's like to split bearing caps..
i have to run one in my rambler (w/4speed) because of it being a "corporate" rear end...i COULD use a dana but i don't see my 290 needing to haul that much extra weight...
can't run a 9" because NHRA sez so...anyway, i've broke those before,too.
tomslik is offline   Reply With Quote
Old 02-28-2013, 10:47 PM   #47
steeldust
steeldust's Avatar
I run 742 and a 489 with 391 gears and 430 gears with a spool and 35 spline axles in a 3200 lbs ROADRUNNER with no problem but i put a brake in and i started braking gears so i put in a DANA in it and all i can say is MAKE ALL THE POWER YOU WON`T TO YOU WON`T HURT IT and now 5.80 AT 126 in a 1/8 in a 3300 lbs DUSTER with a DANA i guess some guys can get a 83/4 to work and they are a good rear end but look if a 83/4 was so strong whay did CHRYSLER put DANAs in HEMI CARS? THINK ABOUT THAT
steeldust is offline   Reply With Quote
Old 02-28-2013, 11:57 PM   #48
toyota1515
toyota1515's Avatar
I will preferred any 8.75 stock rear end against any stock 9" rear end any day,
I have seen 4 cylinder cars break the nose carrier on those stock pumpkins 9" and ruin the day at the track for everybody!
toyota1515 is offline   Reply With Quote
Old 03-01-2013, 12:03 AM   #49
fishy340
fishy340's Avatar
I have a built 8 3/4 489 case w mark williams caps,braced end to end 33 spline mosers and a spool,it will fit a abody w 10" rims 3 1/2 bs.The reason im selling it is im upgrading to a 9".
fishy340 is offline   Reply With Quote
Old 03-01-2013, 01:46 AM   #50
TwoGun
Member
Pullin gears
We used to weld a narrow pc of 1/8" steel in line with the caps on the back of the housing then weld a a 3/8 flangle nut to that in line with the center of the cap. Drill a hole thru and use a socket head cap with a jam nut. Set a very light pre laod (20-25 in/lbs). Seal the screw as needed. Trans brake away,go fast,won't break caps. It worked for us. Or get the aluminum thru-bolt housing,it is a good piece once you change the cheesy thru bolts Mopar put in them.JD Lobosco
TwoGun is offline   Reply With Quote
Old 08-30-2013, 12:19 AM   #51
68Valiant
Member
Pullin gears
68Valiant's Avatar
How strong or how much hp/tq will a stock factory 3.91 489 gear set handle with a spool and 35 spline axles? car is around 3550 with me
1968 Plymouth Valiant 100...500" Indy Headed Pump Gas cruiser....10.49@129
Hick Racing
PumpedNotch/JerseyJumper
68Valiant is offline   Reply With Quote
Resources saved on this page: MySQL 2.30%
