BEWARE OF INDY CYLINDER HEAD - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Classifieds Feedback > Negative seller/buyer feedback
Negative seller/buyer feedback This section is designed to keep everyone informed on bad experiences when buying and selling parts.
Old 04-03-2009, 12:04 PM   #1
DUSTER73
Burnout box
DUSTER73's Avatar
Default BEWARE OF INDY CYLINDER HEAD
I WANT TO MAKE EVERYONE AWARE OF INDY! Their customer service is lacking. I have had two different problems with them and ended up with the same results. The customer is left hold the bad goods. In July I order a rotating assembly and a set of Elderbrock Heads from Indy. Before the Motor was ever started we discovered one of the heads had a bad casting and allowed water to run in the motor on the Number 7 intake. They refuse to send me a new one. ( Motor never started) They did fix this one. After about fifty passes on the motor we decided to change intakes. While changing the intake we discovered a valve keeper in the valley. After further inspection the heads had more keepers broke and about to let lose on the valves. Luckly we caught it before it ate the motor. The vavle springs tested bad. ( 90 Ilbs @ the seat & 240-250 open) We have a solid lift cam 557 lift and shift @ 5,800- 6,000. Indy said the springs need to be replaced and and said it was the cam I'm running. Head are rated from Indy up to 600 lift. Buy with caution! I have gave them the chance to make this right with no luck. Thanks to Royce Thomason our heads for being done right. Have talked to them and sent two e-mail with no response. Talked to Jim and Russ at Indy with no results! Jim stated that I should of told him if I wanted my heads fixed?? Hey Jim that is what the phone calls and e-mails were about!
DUSTER73 is offline   Reply With Quote
Old 04-03-2009, 01:11 PM   #2
mrdragster1970
T/S 368E
mrdragster1970's Avatar
Default Re: BEWARE OF INDY CYLINDER HEAD
I know nothing about dodge stuff. I only want to add, that I have 3 dodge guys I hang with.
All 3 stopped using them several years ago. They had the big rep for being one of the best, especially dodge stuff.
If you ask them, all 3 will tell you way overrated. The stuff might be good when it's right.
But they treated them like crap & did not stand behind what they sold.
All three had fairly small problems & they gave them such a hard time & run around. They all ate the money & never went back.
I know guys swear by them, but I know 3 guys that don't.
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 04-20-2009, 04:23 PM   #3
BV1320
Indy made stuff for Dodges when no one would make anything for them... that said, they have long ago abandoned customer service or found the time to do things properly... they just want your money and then viola ...
BV1320 is offline   Reply With Quote
Old 04-22-2009, 01:47 PM   #4
B-1Duster
And they stole the design from Zeeker.....INDY HEADS SUCK DICK
B-1Duster is offline   Reply With Quote
Old 04-29-2009, 05:26 PM   #5
TheDodgeBoys
Launchin
TheDodgeBoys's Avatar
I have used a few of there products for the LA engines. I have always had good luck, however, they are not the most friendly group of people. They are lacking in customer service! IMO!
1968 SS/AH(CLONE)DODGE DART
1973 PLYMOUTH DUSTER 452
ALABAMA FOOTBALL...ROLL TIDE!
RACER'S FOR CHRIST CHAPLAIN-NHRA DIV.3
"THE LAND OF WINNERS"
BULLET CUSTOM AUTOMOTIVE
LATE MODEL TRUCK AND CAR CUSTOM PARTS AND ACCESSORIES!
270-779-0400
"ANYONE CAN BE A FATHER, BUT IT TAKES A REAL MAN TO BE A DAD!"
"VELOCITY PERFORMANCE SYSTEMS & RACE MUFFLERS", DAVIS MACHINE, MINTON'S MOPARS, RACER'S FOR CHRIST, THE DODGE BOY'S PERFORMANCE
"AND ON THE 8TH DAY, GOD CREATED MOPARS!"
TheDodgeBoys is offline   Reply With Quote
Old 04-30-2009, 01:01 PM   #6
Get dustd
Spooled up
I agree on some points but your machine shop should inspect and test everything before the heads are installed. even if you install them a simple trip to the shop for a p test vacuum check and installed spring hieght and thorough cleaning will give you peace of mind and pinpoint problems before they happen. obvoisly it shouldnt have happend but all performance companys deal with manufacturing issues like this. I would always upgrade valve train components on assembled cylinder heads also because the retianers and keepers and springs are usually junk no matter what they claim there good for and that can be a very costly failure as you almost encountered.
Get dustd is offline   Reply With Quote
Old 05-15-2009, 05:30 PM   #7
1FastMopar
I went through TWO sets of Indy 572-13 CNC heads done by Indy, BOTH sets had more problems then I even want to list! Russ Flagle NEVER did a single thing about any of the problems on either set, one set was a replacement for the first set that failed with no more then dyno time, the second set failed and started leaking water on the dyno too!
The only reason the first set was replaced was because an Indy dealer stepped in and sent me a set, but then Indy PHUCKED the dealer in the end, so even Indy dealers are not safe...
I wouldn't piss on Russ Flagle's head if it was on fire, he is the biggest asshole I have ever met in the industry, but someone came to me who worked for him not too long back, he lowered my feelings of Russ to a whole nother level, the things he told me about Russ while working for him made my jaw drop!! I won't get into details cause I don't want to give anyone any idea who it was, but I will say it was someone who has been in the industry for many years, and he had never seen anything like it before..
1FastMopar is offline   Reply With Quote
Old 05-15-2009, 10:33 PM   #8
Lightners
Lightners's Avatar
Damn, I thought Indy was a reputable place...guess not...wow. We had a S/S head repaired there and it was all good, but that was 15 yrs ago...
Rod Lightner
Lightners is offline   Reply With Quote
Old 05-16-2009, 08:40 AM   #9
BBCStang
TRZ Rocks!
BBCStang's Avatar
Indy is the worst company I have ever had dealings with hands down, no questions asked.
4.31@166 on mt 275 pros
Thanks to:
PTP Racing,NLR NMS-1000 nitrous control,Big Stuff,Bradco Transmissions and Converters,TRZ Suspension components,VP Race Fuels,BES Racing Engines,Double AA Performance,Street & Strip Performance,Schoneck Composites,MacFab Beadlocks,Speedwire, Menscer Motorsports, Mickey Thompson, Armdrop Garage
BBCStang is offline   Reply With Quote
Old 05-16-2009, 06:15 PM   #10
imback
Member
Pullin gears
imback's Avatar
THEY ARE FUCKING SCUMBAG LYING PIECES OF SHIT!!!!!!!!!!!!!!!!!!!!!!!!!!
imback is offline   Reply With Quote
Old 05-16-2009, 11:13 PM   #11
fogged10
Spooled up
fogged10's Avatar
puck indy
muscle motors in lansing michigan ftw!
fogged10 is offline   Reply With Quote
Old 05-19-2009, 06:36 PM   #12
stroker499
Member
Pullin gears
stroker499's Avatar
Quote:
what the fuck do you know.....
stroker499 is offline   Reply With Quote
Old 06-23-2009, 10:40 PM   #13
Gerald Dyer
Spooled up
I bought a Indy intake from them last week, got it in today and it wasn't even close to fitting my combo, with all the info. and BULL they wanted. It will be the last time I ever deal with them!
Gerald Dyer is offline   Reply With Quote
Old 07-21-2009, 05:06 PM   #14
JUICED96Z
JUICED96Z's Avatar
Two of the guys that used to work for them back years ago no longer do and have their own shop and that shop has left a bad taste in a lot of people mouth..... the work is great..... just customer service and the addiude with most people.
You would think that in race country there would be a lot of good shops....... nope....... I am not to far from Indy Cylinder Head....
Another guy "Mike Duke" used to be their head porter back when that shop was the rage and now has his own shop and he does killer work, he is still here in town and has my heads.
My car - I dunno George....
JUICED96Z is offline   Reply With Quote
Old 08-20-2009, 08:20 AM   #15
bottlefed1
bottlefed1's Avatar
Friend of mine used to run a Mopar wedge, bought an Indy block it leaked water into the pan from the base of the #7 cyl I think, then it also leaked oil from an oil galley into the coolant!!!
Indy said that it "looks like the motor had been run really hard" yeah sure alky motor single four barrel no nitrous.
I never really understood what running hard had to do with casting pourosity but I guess that's why I could never be in the PR department of a manufacturer.
Ricard Gavle
bottlefed1 is online now   Reply With Quote
