LS1 Oil pressure problem - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 03-06-2009, 09:33 PM   #1
lowpro64
lowpro64's Avatar
Default LS1 Oil pressure problem
Did a cam and head upgrade on a 02 camaro. Start up was good but now several days (no driving, just running) and a torque convertor install oil pressure is down to 20. I herd the o ring at the pump/pickup may be the problem. Any ideas.
Zim
United States Navy, Retired
lowpro64 is offline   Reply With Quote
Old 03-06-2009, 09:42 PM   #2
Hunter02ss
Launchin
Default Re: LS1 Oil pressure problem
Yes, if the o-ring that go's around the pickup tube where it mounts to the oil pump is not on properly, you will lose pressure. There is actually somebody selling a u shape clamp that go's around the tube and mounts with 2 bolts instead of the one mounting bolt for this reason.
Hunter02ss is offline   Reply With Quote
Old 03-06-2009, 10:43 PM   #3
quickwrench
quickwrench's Avatar
http://www.ls1tech.com/forums/generation-iv-internal-engine/1035445-new-pickup-tube-girdle-lsx-engines-brp.html
quickwrench is offline   Reply With Quote
Old 03-06-2009, 11:11 PM   #4
stage20
you wont be able to tell even with the pan dropped. the pickup tube has to come back out.
make sure you get a new o ring. gm usually keeps them in stock.
i put one of those BRP pieces on my pickup tube. works like a champ. may need some grinding if you run a double chain.
TJ
88 iroc-z/28 408 LSx
all the good stuff.
05 2500HD 6.0L
one hauls, one hauls @$$!
CHP May 2011 feature
http://www.chevyhiperformance.com/fe...aro/index.html
stage20 is offline   Reply With Quote
Old 03-07-2009, 01:34 PM   #5
outkast98
Spooled up
outkast98's Avatar
if it only started after a verter install it could be a cracked oil pressure sensor. we chased the same issue on my car. the shop that did the cam changed the o ring twice and gave up. i was told the motor was tired and i'd have to live with it. i started troubleshooting on my own and found that the sensor was cracked. changed it out and pressure went back to normal. i'm assuming it was from the motor leaning back during the verter install that took place at the same time as the cam. just a thought
outkast98 is offline   Reply With Quote
Old 03-13-2009, 12:56 PM   #6
Shanto
Burnout box
it could also be the gasket on the backside of the camshaft retaining plate...id check there after the pickup tube oring
Shanto is offline   Reply With Quote
Old 03-13-2009, 03:31 PM   #7
lowpro64
lowpro64's Avatar
Thanks to all who replied. We are doing the operation this weekend, and hope the patient is alive afterwards.
Thanks again.
Zim
Old 03-14-2009, 09:31 AM   #8
outkast98
Spooled up
outkast98's Avatar
let us know how it works out
Resources saved on this page: MySQL 1.11%
