DIAMOND RACING PISTONS TRUE 10.5 RULES !!! - Page 9 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Racing Organizations > Milan's Heads-up Shootout - Videos -News - Interviews
Old 02-22-2009, 11:47 PM   #121
outlawbadass7
Member
Pullin gears
outlawbadass7's Avatar
Default Re: DIAMOND RACING PISTONS TRUE 10.5 RULES !!!
Quote:
Originally Posted by proracecrafteng View Post
The NOS guys need to be lighter for sure.
Lighter? I went 8 teens at 2800 lbs. 8 yrs. ago w/ 2 stages and was still learning. So what could someone go today 7.60 -7.70? I think the rules are close the way they are. Just my .02
outlawbadass7 is offline   Reply With Quote
Old 02-22-2009, 11:48 PM   #122
outlawbadass7
Member
Pullin gears
Quote:
Originally Posted by 388Monte View Post
How do these look?
True 10.5 - 1/ 4 Mile Racing, 32 car Field
400 Pro Tree Heads Up Racing Sportsman Ladder
A. Naturally Aspirated
Small Block: 2550 lbs
Big Block: 2750 lbs
B. Nitrous Oxide:
Small Block: 2850 lbs
(Up to two stages, 3 stages or more add #100)
Big Block: 3150 lbs
1 stage of nitrous, multiply stages add #100
C. Turbo Charged and Super Charged
SB Turbocharged: 3150 lbs
(Single 88mm Max Inlet Size Allowed)
Twins not a allowed
SB Supercharged: 3150 lbs
(Gear Driven Blowers Allowed, F1R max. size blower)
Single BBC Turbo/Supercharger: 3300lbs
88mm or F1R Max Allowed (Gear Driven Blowers Allowed)
Turbo & Blower Inlet sizes will be checked with a GO/NO GO gauge
ALL cars must have mufflers - inserts are NOT considered mufflers
Stock front frame rails & suspension required. Aftermarket control arms allowed as long as they bolt in
stock locations. Direct bolt in aftermarket parts permitted. Firewall must be in the stock location. Rack &
pinion steering allowed. Aftermarket coil over shocks allowed and aftermarket direct replacement struts are
allowed. Aftermarket bolt in sub-frame allowed. Must bolt in unaltered to stock OEM mounting locations.
Stock style or ladder bar suspension allowed, no four links
No Wheelie bars
Must be stock appearing interior, with two front seats
Torque converter driven only. Aftermarket heavy-duty cases allowed, air shifters & trans-brakes allowed. Clutchless trans #150
28 x 10.5 wall tire only (No larger, no W tires, Still Wall's Ok) or 275 Radial Tire or Smaller
Done!
Old 02-23-2009, 07:51 AM   #123
Chris Uratchko
Moderator
Chris Uratchko's Avatar
Quote:
Originally Posted by Hemiroid View Post
No F2s also means no blown bbs as the F1 is like putting a powershot kit on a bb, way to small. Milan needs to post some final rules as buying the wrong blower/turbo gets real expensive for us working men
Do you mean, more CID is not a linear thing with an F1 for power? Tell us it ain't so!!!!!!!
Chris Uratchko is offline   Reply With Quote
Old 02-23-2009, 08:01 AM   #124
7secondmalibu
7secondmalibu's Avatar
Quote:
Get off the bullet and answer your damn Lotus Notes will ya?
Special thanks for helping me rebuild:
ScottRodFab.com
TRZMotorsports.com
Gressmanpowersports.com
Tubingjon.com
JR Racecraft
PM me for Laser Etched Chassis Tags.
7secondmalibu is offline   Reply With Quote
Old 02-23-2009, 08:22 AM   #125
Chris Uratchko
Moderator
Very interesting.....
Old 02-23-2009, 08:26 AM   #126
DOUGHBOY RACING
Member
Pullin gears
DOUGHBOY RACING's Avatar
I had my car built to fit in Xtreme Street, since this class is close to that why are tire sizes limited to a 28x10.5 when NMCA states size as this
TIRES–REAR: Racing slicks required. Maximum actual measured tire size is as follows: Actual measured tread of tire is limited to 10.75 inches by 30.5 inches tall. Tire width will be measured by a “go-no go” gauge. Tire width and height will be measured after conclusion of run at scale area. Tire tread may not extend outside fenders.
5.2 WHEELS
My car has 29.5x10.5 and I am not buying more tires
Doughboy Racing
Take no prisoners
DOUGHBOY RACING is offline   Reply With Quote
Old 02-23-2009, 10:10 AM   #127
gilsbachracecraft
gilsbachracecraft's Avatar
Quote:
Originally Posted by CombOverMustang View Post
How about 91.5 max turbo, F2s, gear drives, 2600lbs SB nitrous?
run it
gilsbachracecraft is offline   Reply With Quote
Old 02-23-2009, 10:13 AM   #128
gilsbachracecraft
5.2 WHEELS
your tires are brand new.Sell them or trade them to someone in A/M.
Old 02-23-2009, 10:41 AM   #129
388Monte
Diamond Pistons Rep
388Monte's Avatar
Talked with baxter this morning . . . . .
These should be the final rules . . . .
Big Block: 2750 lbs
B. Nitrous Oxide:
Big Block: 3150 lbs
Twins not a allowed
Single BB Turbo/Supercharger: 3300lbs
No Wheelie bars
Thanks To All My 2015 Sponsors:
Team Z Motorsports
Total Seal
QC Coatings
Diamond Pistons
JCR Transmission
VP Racing Fuels
Mickey Thompson Tires
Scottys Racing Engines
388Monte is offline   Reply With Quote
Old 02-23-2009, 11:12 AM   #130
Trace Meyer
Trace Meyer's Avatar
Big Block: 2750 lbs
B. Nitrous Oxide:
Big Block: 3150 lbs
Twins not a allowed
No Wheelie bars
Nice!!!
Trace Meyer
Team Z Motorsports
Total Engine Airflow
Aluminum Tubing sold here-> 517-403-1914
High Voltage Automotive Wiring (313) 268-0496
Mickey Thompson
P
art Time Performance 419-509-0341
Proformance Racing Transmissions
Ultimate Converter Concepts
Trace Meyer is offline   Reply With Quote
Old 02-23-2009, 11:17 AM   #131
gryphon68
gryphon68's Avatar
That should take the pressure off the nitrous guys . . .
May actually have to limit the nitrous combo's but hopefully that adjustment can wait til 2010. What's the 28x10.5 Nitrous record in the 1/4??
Looks good! Going to need another set of wheels . . . .
Beebe Motorsports
gryphon68 is offline   Reply With Quote
Old 02-23-2009, 11:22 AM   #132
nitrous1
Launchin
nitrous1's Avatar
Big Block: 2750 lbs
B. Nitrous Oxide:
Big Block: 3150 lbs
Twins not a allowed
No Wheelie bars
They look great.
nitrous1 is offline   Reply With Quote
Old 02-23-2009, 11:38 AM   #133
nitrous1
Launchin
nitrous1's Avatar
Probably the best thats out there racing a combo that would fit is sam vincent and he has been 7.40's 3stages,2550#'s with ladderbars. so if you throw 400#'s on him and you go by the 10th per 100# rule that would be mid 7.80s, which is right where everyone at the top of this class should be(7.8-8.0's).I think this first year you'll see alot of 8.2's-8.5's to make up the upper end of the field.
Old 02-23-2009, 11:41 AM   #134
Trace Meyer
hey mark since running 7 anything with a F1R is not much of an effort you should put one together and save all the nitrous fills.
Trace Meyer
Team Z Motorsports
Mickey Thompson
P
Old 02-23-2009, 11:45 AM   #135
ReiKo
YB Monster Crew
ReiKo's Avatar
What did you guys come up with the 4 cylinder guys? Unlimited everything just run a max 28x10.5?
ReiKo is offline   Reply With Quote
