| Trash Or Be Trashed Where the weak are killed and eaten!!!! Vulgar language and nudity may be enclosed!! NWS |
Thread Tools | Display Modes |
#1 |
Spooled up
Hey guys, thought you'd find this interesting.
One of the test rigs I have setup for testing our wastegates applies high amplitude vibration, and at different vector angles, and some setups designed to amplify the effect of gravity. One of the guys that isn't a welder, but just learning, welded this rod to the flange just so that we could test the part. And only after about 10 hours of high amplitude cylcling, the area around the weld cracked. So, proper heat control and penetration is very important with welded parts. Buggar welds are no joke. And, this isn't even under any heat. |
#2 |
Spooled up
That's not even a weld.
Fail. |
#3 |
watch out jimmy will want to try his richard on that test !!!!
#4 |
Launchin
with all that high dollar badass stuff, nobody there can even weld?
#5 |
I'm a bit confused as to how that test is supposed to work after looking at how it's been set up and welded on like that...
Matt Hill Motorsports, LLC | www.matthillmotorsports.com | EFI Calibration & Chassis Dyno Service | Bridgeton, New Jersey ![]() |
#6 |
Burnout box
#7 |
umm thats a v band flange not cast
#8 |
Launchin
that looks more like a braze then a weld
72 Nova - 355/T56 under the knife 05 Denali - Honey Hauler [B[/B] |
#9 |
Burnout box
#10 |
is that bubble gum?
i dont understand this test honestly, your just testing the wastegate for vibrations of your checking someones weld? wouldnt it be better to simulate it off of thinwall stainless tubing to get all the vibrations to it, that bar looks mighty thick to simulate anything
#11 |
Looks to me like you don't have that piece supported properly. With all the weight hanging off that average looking (at best!!!) weld, of course it would eventually fail.
Rob Wade See more of my work..... http://s268.photobucket.com/albums/jj24/mufflrguy/ |
#12 |
Member
Pullin gears
Exactly what i thought.
91, Mustang lx. Best ET. 9.80@135 w/1.35 60ft. 418 ci. Dart based windsor. Vctr jr's by TEA. 12.7 cr. C4 auto w/brake. 28x10.5 m/t,s. stock style suspension. 3430 lbs.
#13 |
Spooled up
Actually, the point is to generate as much vibration to the piece as possible to try to make parts of the wastegate fail. I can move the rod closer or further from the vibrator to change the axial displacement and force.
The whole point of the rig is to make the wastegate fail. But, the surprise was the weld coming apart. It is unbalanced and unsupported on purpose to generate non-linear force against the wastegate. |
#14 | |
Launchin
Quote:
Its not weather or not the rod should be moved closer or further from the vibrator Its how you attach it to the vibrator. That has to be one of the most half assed ways to attach that kind of part to each other. You could have welded that with a perfect weld, and in time it would fail. And the test was to make the wastegate fail.
Never argue with an idiot , they will drag you down to there level, and beat you with experience. ![]() Mike Allem / Race Car Fabrication When you go tens you say what then, nines are fine, but eights are great, sevens your in heaven, sixes are just plain sick, fives you better check to see if your still alive, and fours your knockin on heavens door. |
#15 | |
Quote:
| Thread Tools | |
| Display Modes | |
