bbc cam numbers - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain - LGM Racing and Development
Old 02-03-2009, 06:56 AM   #1
11nos
Pre-Staged
Default bbc cam numbers
got a herbert R274 cam, numbers look like this
@ .050 in 275
.050 ex 286
ivo 13
ivc 84
evo 54
evc 51
but this is whats stumping me, the cam is installed straight up and the intake centerline is 124!!! is this normal? what should it be for a na type performance engine? To shift this number down, do i need the retard or advance the cam install?
the donk is 468 bbc, protopline heads 1.7 rockers, 11.2:1 comp
cheers
derek
I Like NOS
11nos is offline   Reply With Quote
Old 02-03-2009, 08:50 AM   #2
Uncle Paul
Uncle Paul's Avatar
Default
Something looks very wrong with those numbers. At what lift are those valve opening and closing numbers? For comparison look at this comp Cam card which has a similar duration @ .050 lift
http://www.compcams.com/Cam_Specs/Ca...?csid=541&sb=0
Uncle Paul is offline   Reply With Quote
Old 02-03-2009, 04:20 PM   #3
11nos
Pre-Staged
Default
they are at .050". the lobe centre is 108 as well. I installed it with the timing chain in the neutral position, it looks to me like it's massively retarded...
I Like NOS
Old 02-03-2009, 07:00 PM   #4
11nos
Pre-Staged
Default
don't mind me, i goofed up. had the chain one link out. numbers are spot on now.
I Like NOS
Resources saved on this page: MySQL 2.41%
