carb recommendations - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 01-21-2009, 09:17 PM   #1
smblknova
Member
Pullin gears
Default carb recommendations
Built a 406 sbc end of last season AFR 210 aluminum heads .100 dome pistons roller cam approx 575 H.P. question is it seem it wants to lay down about the 450 ft. It pulls good till then. 1.42 60 ft. 6.42 et @ 105 in th 1/8 currently have a Holly model 4150 @ 850cfm. Would a 1050 be benificial? or am I expecting too much?
Thanks guys and gals
awsome site here
smblknova is offline   Reply With Quote
Old 01-21-2009, 10:07 PM   #2
fast406malibu
fast406malibu's Avatar
Default
what you need is a 1000 cfm 4150 carb....
APD carbs & race engines..
Fleenor Racing Powerglides
419-280-1406
BTE, Hughes & Trans Specialties Dealer.
http://www.youtube.com/watch?v=iW-5g...ature=youtu.be
http://www.youtube.com/watch?v=f0cho...ature=youtu.be
fast406malibu is offline   Reply With Quote
Old 01-21-2009, 11:34 PM   #3
xcelr8
xcelr8's Avatar
Default
Quote:
x2 Preferably one built by APD!
xcelr8 is offline   Reply With Quote
Old 01-21-2009, 11:47 PM   #4
Eddie McDow
Spooled up
Eddie McDow's Avatar
Smile Carb question
Call Chuck Nuytten,tell him what you got,combination you have,what you are going to want to do with it.972-722-8333
www.chucknuytten.com
Eddie McDow is offline   Reply With Quote
Old 01-21-2009, 11:58 PM   #5
imback
Member
Pullin gears
imback's Avatar
Default
Maybe get a 950 and try it,my 383 has a flat tappet cam,dart 215 iron eagle platinums,13.5-1 comp.,with a super victor, made 592 hp. on alky and thats the carb i have.
Id call APD if i needed another carb they seem to be really knowledgeable and could help you out.
imback is offline   Reply With Quote
Old 01-22-2009, 07:44 AM   #6
Hammertime
Hammertime's Avatar
Default
950... go here www.apdracing.com call them, any of them guys will be able to give you the info you need and help you out with a carb
Hammertime is offline   Reply With Quote
Old 01-22-2009, 01:03 PM   #7
cci
Spooled up
Default
Contact Patrick at ProSystems: http://www.prosystemsracing.com/index1.html
He is great to deal with and ships within days.
cci is offline   Reply With Quote
Old 01-22-2009, 01:14 PM   #8
Pwraddr
Launchin
Pwraddr's Avatar
Default
X2
1989 Notch
1992 Notch
Windsor/C4
Pwraddr is offline   Reply With Quote
Old 01-23-2009, 08:30 AM   #9
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Default
either an 850 or 950 from quick fuel
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
Old 01-23-2009, 01:20 PM   #10
White90GT
Default
What have you done to try to remedy the problem at this point? Have you jetted it up a bit more? How do the plugs look after a pass?
I'm assuming you basically have a 750 carb with an 850 baseplate which is what I have with a similarly powered SBF.
Carl Smith: 2014 Mustang GT Premium Ruby Red Daily Driver
80 Coupe with a few goodies...
White90GT is offline   Reply With Quote
Old 01-23-2009, 08:18 PM   #11
Horndog
Default
X2
Can't believe that it was nine posts in before someone wasn't wanting to sell you a carb or recommend a builder.
Like White90GT said, we need to know some things here first. That 850 will provide most if not all of your needs.
If it is laying over, typically that's a symptom of running out of fuel. What fuel pump are you running ?
If electric, is it getting the proper voltage ?
What is the fuel press going down track ?
What size fuel line from tank to carb - everything:
tank to pump, pump to regulator, regulator to carb ?
Is the filter clean / new ?
Jetting ?
Timing / ignition ?
Any popping when the engine lays over ?
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
Horndog is offline   Reply With Quote
Old 01-23-2009, 08:45 PM   #12
Honk if parts fall off
Drag Week Survivor
Default
I would first get a wideband 02, then tune the carb you have... it will save you hundreds of $$$$...
Honk if parts fall off is offline   Reply With Quote
Old 01-23-2009, 09:11 PM   #13
70bbc
70bbc's Avatar
Default CFM
cfm all the way hands down dale cubic
70bbc is offline   Reply With Quote
Old 01-23-2009, 11:09 PM   #14
79Lemans
Pre-Staged
79Lemans's Avatar
Default
I think it is in your fuel delivery,i would check that first.
79Lemans is offline   Reply With Quote
Old 01-23-2009, 11:18 PM   #15
Dr. Evil
A.K.A. MEAN Matt
Dr. Evil's Avatar
Default
awsome site here
Do you have jet extentions? do you have enough fuel pressure going down track?
APD stuff is bad ass but if you can fix the problem without buying a new carb........
The Speed Shop. Ann Arbor / Ypsilanti Mi 734-325-3861
Dr. Evil is offline   Reply With Quote
