Down Pipe Size vs. Power Loss or Gain - Yellow Bullet Forums
Old 01-16-2009, 09:57 AM   #1
craigs
Default Down Pipe Size vs. Power Loss or Gain
I am in the process of changing turbo location on a customers car.
Working closely with both the engine builder and the car owner, the discussion has been brought up regarding down pipe size.
In moving his turbo from the driverside to front and center (Forward Facing) I have ran into a situation where the optimal 5" downpipe will no longer clear the motor plate and still allow the bumper cover to clear the compressor housing.
So my next choice would be to neck down to 4", as I can get a tighter CLR bend and have plenty of room to clear the motor plate.
My concern was that the 4" would cause some restriction with either back pressure or power loss.
So being the inquizative person I am, I started making some phone calls. First to Precision turbo. Although they stressed the use of the 5", I didn't get a clear answer as to why or why not the 4" would work.
After speaking with a few more companies I get pretty much the same response, yet no clear answer as to why necking down the tubing size will or will not affect performance.
Does anyone have a clear answer on this subject? Has anyone actually performed any comparisson tests that can prove or disprove this theory?
Is there a mathmatical formula for calculating optimal tube size?
I know there are a ton of variables, as each engine is different, but there has to be some facts associated with determining the correct size.
Any help will be greatly appreciated.
Thanks in advance,
CraigS
craigs is offline   Reply With Quote
Old 01-16-2009, 10:31 AM   #2
Injected65
Injected65's Avatar
Default
Here is my personal theory:
5" downpipe = 19.63 sq inches of area which would be the same as dual 3.5" pipes.
Now if I was working with a 400" motor with a 101 turbo making 2000 hp, then I sure would want a 2000 hp N/A motor with at least dual 3.5" exhaust (obviously bigger bit we are limited to a 5" outlet on the turbo).
Using a 4" downpipe in the same calculations results in 12.56 sq inches and the same area as dual 2.82" pipes.
Now obviously this is my backwoods redneck way of calculating things. Hopefully someone with more expertise than my one night stay at the Holiday Inn Express will chime in
Chris
C & B Motorsports - www.candbmotorsports.com
Innovators West - www.innovatorswest.com
Injected65 is offline   Reply With Quote
Old 01-16-2009, 11:07 AM   #3
DaveH
DaveH's Avatar
Default
Gimme the cid of the engine, the redline you plan to use, and what sort of boost pressure you plan on. I can run the numbers and let you know the velocity and backpressure on 4" and 5" pipe.
DaveH
'94 Supra
7.77 @ 176 mph
183 cid - 1114 rwhp on E98
“Americans are so enamored of equality, they would rather be equal in slavery than unequal in freedom.”
“The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money.”
DaveH is offline   Reply With Quote
Old 01-16-2009, 11:17 AM   #4
Frank02L
Member
Pullin gears
Frank02L's Avatar
Default
Can you fit 4.5"? Thats what we put on the s10 build, same type deal, turbo location vs engine location...
Needing to find wheels... apparently
Frank02L is offline   Reply With Quote
Old 01-16-2009, 11:23 AM   #5
craigs
Default
Quote:
Cid = 352
Redline= 9000
Boost = 25lbs
his is with a Precision 98/85
he will also be switching out with a true 94 to run Orsca EZ street and will probably see around 30 lbs with that unit.
Thanks for your help. Do you mind sharing the formula that you are using to determine the velocity and backpressure?
Old 01-16-2009, 11:32 AM   #6
craigs
Default
Quote:
Actually I have concidered that. Does anyone make a flange that will go from 5.00" to 4.50" or did you flare the 4.50" tubing?
Old 01-16-2009, 11:43 AM   #7
go green
Environmental Hazard
go green's Avatar
Default
I was wondering the same thing .
I have 4.5 V-bands on my exhaust out and I am wanting to go to 4" aluminum .
I am having a hard time finding 4.5 tube in stainless or aluminum that is not crazy money . I can build it in 4'' aluminum for 60% cheaper and easier to fit.
Looks to me like this guy here runs 4" and he goes pretty fast.
BAE 8X Turbo
https://www.youtube.com/watch?v=YX86DHGKBo0
go green is offline   Reply With Quote
Old 01-16-2009, 11:53 AM   #8
Frank02L
Member
Pullin gears
Frank02L's Avatar
Default
Quote:
I think we machined our own flange, IIRC.
Old 01-16-2009, 12:45 PM   #9
roozterdvx
roozterdvx's Avatar
Default
how about sectioning the 5" elbow to tighten up the CLR?
taking a few "pie cuts" out of the short side might get you the room to use the 5" without reducing it
The Roozter #9876
http://tinyurl.com/murfftribute
Yea, though I walk through the valley of the shadow of death, I will fear no evil: for you are with me; your rod and your staff they comfort me.
roozterdvx is offline   Reply With Quote
Old 01-16-2009, 01:42 PM   #10
Injected65
Injected65's Avatar
Default
Keep in mind that on twins you only have half the engine's exhaust to worry about.
Chris
Old 01-16-2009, 02:02 PM   #11
DaveH
DaveH's Avatar
Default
I make some wild ass assumptions on the engine ve etc and then plug in the flow into a duct sizing software I have. at redline:
4" pipe - 8.5 psi of backpressure per 100' of pipe
5" pipe - 2.6 psi of backpressure per 100' of pipe.
Cid = 352
Redline= 9000
Boost = 25lbs
DaveH
'94 Supra
7.77 @ 176 mph
Old 01-16-2009, 03:10 PM   #12
Frank02L
Member
Pullin gears
Frank02L's Avatar
Default
So if you have 5' of pipe, the difference is .425psi backpressure on 4" and .13psi backpressure on the 5"???
Old 01-16-2009, 03:11 PM   #13
Brian Robards
Pre-Staged
Default
You also need to remember that the backpressure seen at the engine is equal to [(pipe backpressure + ambient)* expansion ratio of turbine] - ambient pressure
So if you have an expansion ratio of 2.5, your engine backpressure will for the 4" will be (8.5+14.7)*2.5 - 14.7 = 43.3 psi
For you 5" it will be (2.6 + 14.7)*2.5 - 14.7 = 28.55 psi
So, the biggest exhaust you can get in their, the better. A lower engine backpressure will decrease your BSFC and increase your VE, resulting in more power.
Brian Robards is offline   Reply With Quote
Old 01-16-2009, 03:12 PM   #14
Brian Robards
Pre-Staged
Default
no the per 100' is the Length of the pipe.
Old 01-16-2009, 10:47 PM   #15
veee8
Launchin
veee8's Avatar
Default
On my car, I have 5" pipe out of the turbo and continues on about 3.5 feet. Now I am planning on reducing at the end of the 5" down to 4", and get a 4" in/out oval straight through muffler and a turn down. It is just too loud with the 5" to drive on the street. How much am I hurting by doing this?
www.virginiaspeed.com
veee8 is offline   Reply With Quote
