what does it take to build a 750 hp bbc on pump gas - Yellow Bullet Forums
Old 01-11-2009, 11:53 PM   #1
1 bad import
Default what does it take to build a 750 hp bbc on pump gas
i just bought a 1979 malibu ,im wanting to build it to be a cruiser and run on pump gas ,and run the 10.0 index on motor but still take it to the shore for a weeken drive ..
im figuring the car will weigh 32-3300 lbs i plan on getting fiberglass bumpers and a deck lid and taking some weight out of the frame with a tubular front where the motor mounts and getting tubular a arms ect ..
should i be shooting for like a 540 ci motor or can i do it with a stock crank and stroke 454 bottom end ..what are some budget heads i can get (used ot new )i was planning on running a i beam rod with steel crank and some forged pistons in a stock block ..
can i get away with a hydrolic roller cam or a flat tappet im trying to stay away from big lift solid rollers .i just wanted the pistons and crank just in case down the road i put a plate on it ..
what kind of combo can i expect to have to build with a bbc ???
1 bad import is offline   Reply With Quote
Old 01-11-2009, 11:55 PM   #2
1 bad import
Default
reason im posting is i already have a 383 higher compression motor that will get me close at less weight if i have to put compression in the motor im going to stick with what i have ..
Old 01-12-2009, 01:05 AM   #3
mikeyfrombc
mikeyfrombc's Avatar
Default
no idea on the bbc set-up but my buddies 436sbc would fit the bill it,s been in the 9.60,s all motor on 94octane and has a hyd roller , 23deg heads , he does have a killer convertor( 8" coan 5500stall ) in the set-up , but it,s streetable i spent 4 hrs oneday crusing in it and no issues even on the highway for 30miles
Demon Precision Products
mikeyfrombc is offline   Reply With Quote
Old 01-12-2009, 08:10 AM   #4
1 bad import
Default
my old sbc 355 went 10.6 -10.7 all day long @10.5-1 compression but i have no expeirience with big block combos ..
will a good selection of parts get me to my goal ?im trying to run the index on pump w/o nos ..
Old 01-12-2009, 08:55 AM   #5
revolutionary
revolutionary's Avatar
Default
You can do it but you'll need to spend some money on the heads to get it right and still be really driveable. A well ported set of ~320 heads, no reason to run a hyd roller, get a solid roller - numbers depend on how the heads are, 10.5:1 comp and you should be able to hit 750.
Daryl
Revolutionary Performance and Machine
revolutionary is offline   Reply With Quote
Old 01-12-2009, 08:20 PM   #6
SmallBlockNova
aka Nova Joe
SmallBlockNova's Avatar
Default
My engine builder's son has a 496" BBC, pump gas, Brodix heads, Comp solid roller and a Pro Systems 1050 dominator and it made 765hp on a "real" dyno. Drives it everywhere, no problems.
Thrift-Way Auto Body & Chassisworks
www.thriftwayautobody.com
Al-Lee Motorsports - BAE - Resolution Racing - Ross Pistons - Quickdrive - Neal Chance -
Redline - New England Racefuels - Goodridge Hose - ASi Racewear - MSR
SmallBlockNova is offline   Reply With Quote
Old 01-12-2009, 08:40 PM   #7
pat565
Senior phuckstick
pat565's Avatar
Default
I've seen two different bbc based on 540 CI making enoughower to hit high 9's with one, and bottom 10's with the other. Both ran the same bottom end. Mine was eagle rot assembly, 748 lift cam (i don't remember duration, but i could find it) and topped with pro1 345's. Single plane intake with a 1095 king demon. It ran 9.85 at 3000 lbs at 3500 ft elevation. One guy that races with us, had the same bottom end, but 305 cc heads, a smaller cam, and EFI. He is running a very street friendly Monte Carlo (read heavy), and has hit 10.10's at same tracks on premium.
pat565 is offline   Reply With Quote
Old 01-13-2009, 04:36 AM   #8
gmracing355
Default
Allen, You have too much time on your hands,lol
Greg
gmracing355 is offline   Reply With Quote
Old 01-13-2009, 07:24 PM   #9
1 bad import
Default
actually right now withthe new baby i dont have alot of time but for some reason i always just have to build stuff ..
last year was the 331 sbf rx7 convertable 1990 fc ,sold it after the summer ,had a manual vb aod with electric od ect and a 331 sbf
then before that it was a 2 fogger 1988 gti with a 2.0l swap dropped on some radials ,went 12.50 and was a nice driver
motor
before the gti it was the jeep for my wife ..
im gonna put up a post my life building cars ..i have built almost a car every year for about the last 12 years ..i dont know why i just love pulling stuff apart and making cars the way i want them ..
now the new project is a 79 malibu ..
Old 01-13-2009, 08:22 PM   #10
z289sec
z289sec's Avatar
Default
Just buy my 509 I have for sale in the parts section!
It went 6.3xx's on motor in a 3280 lb car on pump gas.
z289sec is offline   Reply With Quote
Old 01-13-2009, 09:34 PM   #11
1 bad import
Default
post a link ..
Old 01-13-2009, 10:41 PM   #12
JeffMcKC
JeffMcKC's Avatar
Default
If there is no Cube limit the bigger the better on pump gas, there is a diminishing return on HP per cube when the fuel used is a limiter, more cubic inches more power why use a 454 when a 615 will do.
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 01-13-2009, 10:44 PM   #13
Mike77z
Mike77z's Avatar
Default
My 581 made 815 horse on a very easy tuneup 9 - 1 6500 rpm
Dart pro 1 355 cnc bullet cam
1977 Z28 Street Car TRZ control arms QA1 coil overs
Backhalf by www.crillychassis.com
581" BBC / TH400 by West Carelton Automotive 815 horse 763 TQ on 91 octane
Mike77z is offline   Reply With Quote
Old 01-14-2009, 07:37 AM   #14
Drag Radial King
Drag Radial King's Avatar
Default
Should go tens with ease. My junk weighs 3500# with me in it.
Had Dart 325's and ran 10.30 on 91 octane, just switched to Dart 335cnc's and Merlin X intake, shoot'in for 9.80's
Drag Radial King is offline   Reply With Quote
Old 01-14-2009, 09:08 AM   #15
revolutionary
Default
My friend just swapped his small block for a 540 (don't know if the guy is on here) and the 540 is 10:1 with BB2x cnc ported heads and a 454R intake and based off the et he was running makes right about 725-750. that was with a 274/282 solid roller.
Daryl
Resources saved on this page: MySQL 1.03%
