Super Blue 007 Fuel Additive??????????? - Yellow Bullet Forums
Old 01-04-2009, 10:54 PM   #1
cbunn
cbunn's Avatar
Default Super Blue 007 Fuel Additive???????????
Has anybody ever heard of this additive and has anybody ever run it.I have talk to a racer that has mixed it with Sunoco Maximal 116 and it picked up on the track.I did some research on it and it says to add 1 gallon to every 4 of your racing fuel.It says you should see an increase in HP by 12%.I was wondering if I could use it with some Q16 or is that asking to much?
Thanks for any info!!!
Later
Craig
1989 Mustang GT Had it new since 11-88
Started with a set of gears in 1990 and
after many combos over the years the
current is below
N/A SBF on 28's with SS and No Bars
Thanks to the following
B&D Racing Engines
Duane Busch Cylinder Heads,Duane helped with the whole combo
Herrings Garage,from paint and body to fab and fuel and in between
Tyson Automotive,for everything over the years
Baseline Suspension, Mid 1.20 sixtys with the best of a 1.21 sixty
cbunn is offline   Reply With Quote
Old 01-04-2009, 10:56 PM   #2
Chris Uratchko
Moderator
Chris Uratchko's Avatar
Default
Use it with Q16?? Q16 is already oxygenated.... how about you use it and let us know how it works? LOL Just kidding, I'd be leary about mixing any kind of power adder fuel mix with an already oxygenated fuel.
BTW- Craig, car looks great!! Got your pix!!
Chris Uratchko is offline   Reply With Quote
Old 01-04-2009, 11:26 PM   #3
cbunn
cbunn's Avatar
Default
Thanks,thats kinda what I was thinking?It was just wishful thinking?Chris have you or anyone else ever run it and had good results?I know of one person that's run it an d it worked pretty good.I wished I had tried it on the dyno so the jetting,timing etc... would be close but I'll probably try some after I get the bugs worked out.Chris it's been five long years since I have run it.New paint,new brakes,new suspension etc....I just hope I have the bugs knocked out without a lot of trouble.It would nice to run that oo7 if it will pick it up 12%,Q16 says you'll pick up @ 5-6% and that's what I picked up.So if the 007 will work I may have to try it.
Thanks for the input
Craig
current is below
B&D Racing Engines
Old 12-26-2010, 02:26 PM   #4
JCPERF
Launchin
JCPERF's Avatar
Default Re: Super Blue 007 Fuel Additive???????????
Has anyone else tried this additive?
THE INTERNET,MAKING COMPUTER NERDS INTO TOUGH GUYS FOR 19 YEARS
JCPERF is offline   Reply With Quote
Old 12-28-2010, 10:44 PM   #5
SAMMY CHRISTIAN
Launchin
SAMMY CHRISTIAN's Avatar
yes, waste of about $250. no improvement, failed fuel check. mixed with C25, fuel check guy asked if someone cleaned fuel system with brake-kleen. still have @3gal-$100 can have it
SAMMY CHRISTIAN is offline   Reply With Quote
Old 12-28-2010, 11:03 PM   #6
youngengines
youngengines's Avatar
I spoke to World wide racing fuels concerning the 007 and was told if you are running Q16 you would most likely see no gain. I havent tried either, but plan too. I was told that there were some guys running the 007 a while back with improvements, but cant be for sure.
youngengines is offline   Reply With Quote
Resources saved on this page: MySQL 1.16%
