ball bearing vs. journal bearing - Yellow Bullet Forums
Old 01-02-2009, 01:16 AM   #1
1fastacvw
Member
Pullin gears
1fastacvw's Avatar
Default ball bearing vs. journal bearing
im getting ready to buy a new turbo and would like some input between a bb turbo vs journal bearing.
the bb turbo spools quicker then journal but in a drag race situation once spool at the line does it really make that much difference when you leave. i could see in auto it wouldnt but in manual maybe it would becuase of rpm drop.
my car is manual, rpm drop is prob 4k max between gears.
ty
dean
1fastacvw is offline   Reply With Quote
Old 01-02-2009, 01:58 AM   #2
ASH
mfi turbos rule
ASH's Avatar
Default
bb will spool slightly quicker...
the bb will recover quicker on a pedel , and gear change
they both should provide the same over all performance
more to do with the tune
ASH is offline   Reply With Quote
Old 01-02-2009, 02:01 AM   #3
ssomustang50
Member
Pullin gears
ssomustang50's Avatar
Default
in a small cube motor say around 350ci a bb turbo would be better. The more cubes,the more it will help the turbo spool. So bigger cubes a journal turbo would spool just as fast.
ssomustang50 is offline   Reply With Quote
Old 01-02-2009, 03:36 AM   #4
stony
Member
Pullin gears
stony's Avatar
Default
This may not be true with all BB turbos but something i found out was most BB center housings are not rebuildable. Where most if not all journal types are. I just rebuilt my mitsu t-88 for 100 bux and it's running strong.
5.3 truck motor, BWs480, BTR stage 2 Cam, LS7 MLS gasket, custom intercooler, AEM infinity EMS, 2 speed powerglide, Fully built Ford 8.8, 4:56 gears/spool, 4 link suspension.
stony is offline   Reply With Quote
Old 01-02-2009, 03:43 AM   #5
ASH
mfi turbos rule
ASH's Avatar
Default
Quote:
turbonetics bb are......
Old 01-02-2009, 10:05 AM   #6
turbojd331
Spooled up
turbojd331's Avatar
Default
BB are good by theory, but today's designs can't handle surge and shaft motion as well as journal bearings. Also most of the time you have to control spool-up after you launch for traction thru a boost controller anyway to prevent tire spin. If you are on a limited budget there are better places to spend you money.
turbojd331 is offline   Reply With Quote
Old 01-02-2009, 10:37 AM   #7
Shearer
Shearer's Avatar
Default
In my experience Garret's BB turbos are a good bit more durable than other journal bearing turbos, referring to gt30-gt42ish sized turbos.
A while back we did some comparison's between BB and non-BB GT42's. On the Anti-Lag the BB unit got to it's boost target 1/10 of a second or so quicker. On gear changes the time it took from going 100% throttle to full boost was a wash.
Borg Warner, Callies, DART, Davies Craig, Diamond Pistons, Earls, Forced Performance, Garrett, Holley, K1, Precision Turbo, Stainless Works, TiAL, Trick Flow, Turbosmart, Vibrant, Wiseco, Xona Rotor Turbos
Dealer inquiries are welcome
216-242-2909
www.shearerfabrications.com
sales@shearerfabrications.com
Shearer is offline   Reply With Quote
Old 01-02-2009, 11:08 AM   #8
1fastacvw
Member
Pullin gears
1fastacvw's Avatar
Default
interesting, im looking at getting a gt4294.
how are garretts for rebuilding is bb.
ty
dean
Old 01-02-2009, 11:14 AM   #9
Shearer
Shearer's Avatar
Default
I don't think they are rebuildable. Garret has some kind of exchange program for them though.
If you're looking into a BB 4294 give me a call. I have a used one off my car I want to get rid of.
216-242-2909
Old 01-02-2009, 12:31 PM   #10
coupe
الكتاب المقدس حزام سير
coupe's Avatar
Default
Quote:
+1
Not to mention the ball bearing designs used in turbochargers may be exceeding their RPM design limits in certain applications.
One of the principal tasks of the logical analysis of a given proposition is to find out the method of verification for that proposition. - Rudolf Carnap
coupe is offline   Reply With Quote
Old 01-02-2009, 01:35 PM   #11
Marty Staggs
Launchin
Marty Staggs's Avatar
Default
ESPECIALLY in thrust wear.
Comp Turbo have their own bearing system and its completely re-buildable.
http://www.turbosmartusa.com/
Marty Staggs is offline   Reply With Quote
Old 01-02-2009, 01:52 PM   #12
Collinsautomotive
Default
I would love to see a shaft Tq requiremtn test for a BB vs pressurized journal. I'd bet that the Journal actually outperforms the BB in many ways. I think the advantage in a BB is in initial moment of inertia.
Quote:
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 01-04-2009, 02:19 AM   #13
Nick James
:D
Nick James's Avatar
Default
This thread is full of good information and also bad information.
Garrett doesn't have a warranty exchange program for turbochargers LOL. In fact Garrett's warranty is just about non-existent. Its always "user error" that the turbocharger fails and I have never seen them warranty a turbocharger, ever. You also HAVE to run the coolant lines if your looking to get a turbocharger replaced under warranty (through Garrett and their GTR series line)
Every single turbocharger I've ever seen has been a rebuildable unit unless its one of Garrett's DUAL BALL BEARING units (GTR SERIES). There are other manufactures that use Garrett CHRAs and put their name on them.(Rumors have it that there are reputable shops that are developing tooling to rebuild these GT series turbocharegers but I haven't heard anything yet)
Peak power should still be the same (BB vs. NON-BB) but you'll see more power sooner with the BB units.
BB units are also more durable then a journal bearing. Once you wipe the thrust out of the turbocharger, muah, kiss your turbocharger bye bye.
Usually a non-rebuidable turbocharger is because of the following: a) its a dualbb unit b) forgeign debris got into the oiling system causing scaring to the turbine shaft c) compressor wheel/turbine wheel made contact with turbine housing/compressor housing which can d) cause the turbine shaft to get bent as well. Now you might be able to rebuild the unit in certain circumstances but usually its cheaper just to buy a new one. Maybe thats why some get confused when they here "this isn't rebuidable"; I dont know.
Now with that being said, I would buy a ball bearing unit. Which brand though? I sell both Garrett and Turbonetics but like I've listed above, you can't rebuild a Garrett (GTR series) and they dont have a warranty.
Turbonetics will give you a 1 year hassle free warranty NO MATTER what happens to it INCLUDING user error. (That warranty even applies to their nonbb units as well fyi). Our Sponsored Comp car, Mark Wolfe, runs Turbonetics turbochargers and holds the world record in AA/AT.
When your ready to buy or would like help pricing a unit out, let me know and I'd be happy to help. I do carry Garrett as well.
Nick
Accel DFi Turbonetics & Spearco TiAL K&N Garrett Precision
Custom RACE Turbo Systems/Headers & Fabrication Parts & Accessories
Nick James is offline   Reply With Quote
Old 01-04-2009, 11:23 AM   #14
Shearer
Shearer's Avatar
Default
Quote:
They do have an exchange program. And they have actually footed the bill for a 35r for me before.
http://www.turbobygarrett.com/turbob...BBService.html
Turbonetics warranty is the best out there though, as long as you don't removed the oil fitting. Can't beat a no questions asked replacement, which is awesome as you'll probably need to use the warranty. I've never had good luck with there product but I do hear it is much better than just a couple years ago.
216-242-2909
Old 01-04-2009, 06:38 PM   #15
Nick James
:D
Nick James's Avatar
Default
Wow.. This is new to me. I've never seen that link on their site before. Good to know.
