Is this a decent cam? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 12-28-2008, 06:55 PM   #1
10.5
10.5's Avatar
Default Is this a decent cam?
A friend of mine has an engine that is set up to be a "nitrous" engine. The cam in it is absolutely huge. Do you think it's too big?
.816/.803
274/294 @ .050
116 LS installed @ 113
Valve events: OPEN--int 24*BTDC, exh 86* BBDC, CLOSE--int 70*ABDC, exh 28*ATDC
Engine is a 440" windsor, 4.070 x 4.23
~13.4:1 compression ratio (1.3cc dome)
Victor Jr's (flow 324 on intake)
Super Victor
Motor only has ~155 lbs cranking compression...is this normal and due to the cam size?
Thanks!
10.5 is offline   Reply With Quote
Old 12-29-2008, 10:43 PM   #2
Modified Street Mustang
Launchin
Default
I think its too much camshaft. Do those heads actually flow at .800 lift?
Modified Street Mustang is offline   Reply With Quote
Old 12-29-2008, 10:58 PM   #3
Sam Vincent
Sam Vincent's Avatar
Default
Quote:
.816/.803
274/294 @ .050
Super Victor
Thanks!
Not really. how heavy is the car? and how hard are you going to spray it?
sponsors:
Nitrous Express, Diamond, JESEL, Marcella Manifolds, M/T, VP racing fuel, GRP, Bullet Cams, RacePak, Leashed Elect, ATI performance
Vincent Performance
Graham KY
270-977-1893
Dealer:
Diamond, Trend, TotalSeal, BulletCams, Morel, Jesel, Brodix, Moroso, Manton, GRP, Callies, PSI~PAC, Stef's, Nitrous Express, TrickFlow, TotalEngineAirflow, PTC converters, William's Perf, ProLite batt, UltraPro Machine, Danny Bee, ATI Perf, MOSER Engineering, Sonnax Industries, PST shafts...
Sam Vincent is offline   Reply With Quote
Old 12-29-2008, 11:04 PM   #4
Collinsautomotive
Default
looks like it might be in the ball park. Depending on the headers that LSA may need to be tightened up but you might wanna chase the ICL around before trying that if the car is unresponsive to tunning changes.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 12-29-2008, 11:25 PM   #5
10.5
10.5's Avatar
Default
Car weighs 2950lbs w/ driver
Here is the flow sheet: (intake only) All at 27.95 depression
.300--186.1
.350--211.5
.400--236.1
.450--262.8
.500--284.3
.550--299.1
.600--315.6
.650--324.8
.700--324.8
.750--320.1
.800--321.2
.850--325.5
.900--324.3
.950--326.2
Planning to spray somewhere in the range of 34N/30F or 36N/30F on an Edelbrock fogger w/ E-2's.
Headers are only 1 3/4 to 3" collectors--3" exhaust to the axle.
It just seems that this cam bleeds so much cylinder pressure, but I'm just curious with the amount that will be sprayed, will it be fine? How much more (if any) power could be picked up with a smaller cam?
Thanks for the input!!!
Old 12-29-2008, 11:44 PM   #6
Collinsautomotive
Default
Cranking compression is not terriably useful for figuring out what cylinder pressures will be in the intended operating range.
Run it and see what happens. IMHO the headers are to small so that wide LSA will help you. If you are after more cranking compression though advance the camshaft if you have sufficient Piston to Vlave clearance.
.300--186.1
.350--211.5
.400--236.1
.450--262.8
.500--284.3
.550--299.1
.600--315.6
.650--324.8
.700--324.8
.750--320.1
.800--321.2
.850--325.5
.900--324.3
.950--326.2
Old 01-01-2009, 02:55 PM   #7
dotdot
Pre-Staged
Default
top post is right.
dotdot is offline   Reply With Quote
Old 01-01-2009, 04:11 PM   #8
team hyperactive ez555
Default
heads and headers to small for cid and camshaft, it will work but can be alot better.
team hyperactive ez555 is offline   Reply With Quote
Old 01-02-2009, 09:28 AM   #9
10.5
10.5's Avatar
Default
Quote:
That's exactly what I thought...kinda stuck with those heads though. That being said, would this set of heads/headers make the best power with a smaller cam, or will this cam do fine. It's one thing to be down by 10-20 hp with this cam...but I'd hate to know that the motor is down by 50+ hp over a better cam.
What is the total amount of spray that this combo could handle with this cam, assuming the tune-up is perfect?
Thanks for all input!
Old 01-08-2009, 05:34 PM   #10
BTL FED
In Glock I Trust
BTL FED's Avatar
Default
How did you put SBC headers on a BB?
BTL FED is offline   Reply With Quote
Old 01-11-2009, 06:43 PM   #11
s10racr
Burnout box
Default
Those headers are small for sbc.
s10racr is offline   Reply With Quote
Resources saved on this page: MySQL 89.13% / PHP 73.29%
