SBC thrust bearing problems - Yellow Bullet Forums
Old 12-27-2008, 12:38 PM   #1
coony278
Spooled up
coony278's Avatar
Default SBC thrust bearing problems
I'am assembling a 383 engine. The engine has a fresh line hone done.
When I put the crank in and torque down the rear main cap the engine locked up. Checked the end play with the cap torqued and it has none.
With all the other caps torqued down and the rear cap removed the engine turns perfect. And has 6 thousandths end play.
My machinist said this was common and to sand the thrust side of the bearing until cleances was correct.
I did this and the engine turns freely and has proper end play now.
Now I trust my machinist but this just seems wrong to me.
What would you guys do ? I'am thinking about returning the block to the machine shop that lined honed it. My machine shop does not line hone. I had BB&T in memphis line hone it and I believe them to be a good machine shop.
Any input would be appreciated.
coony278 is offline   Reply With Quote
Old 12-27-2008, 01:19 PM   #2
CNC BLOCKS
CNC BLOCKS's Avatar
Default
Make sure you have the correct size rear main bearings!!!!
See if the front or the rear of the main caps has been cut as one side of the cap has to be squared to the bottom of the cap so it can be cut square.
Make sure its the right cap and if there is a dowel pin for aligment remove it and set your own thrust clearance like what you would do on the late 350 blocks.
I should be around today give me a call 207-892-7215
CNC BLOCKS is offline   Reply With Quote
Old 12-27-2008, 10:48 PM   #3
coony278
Spooled up
coony278's Avatar
Default
I'll give you call monday. Thanks
Old 12-29-2008, 10:04 AM   #4
revolutionary
revolutionary's Avatar
Default
Did you set thrust? My favorite part of assembly! torque them all, loosen up the rear cap 1/4-1/2 turn until you feel the pressure release but the cap is still not flopping around. give the front of the crank a good whang with a rubber mallet. Same to the rear if possible. If you can't hit the rear (no pun intended) wedge a screwdriver between one of the main caps and a counterweight forcing the crank forward as you tighten up the rear cap. That should align the rear faces the of the thrust flange and loosen up the crank.
Daryl
Revolutionary Performance and Machine
revolutionary is offline   Reply With Quote
Old 12-29-2008, 03:31 PM   #5
66 AC COBRA
66 AC COBRA's Avatar
Default
had to do the same thing to gain a few thou clearance, my machinist and engine builder both do it this way (both good and respected in the area), motor had been down the track about a 100 times, apon inspection, everything is perfect, end play is still .007 as set
FLATIRON RACECARS
66 AC COBRA is offline   Reply With Quote
Old 12-29-2008, 09:36 PM   #6
coony278
Spooled up
coony278's Avatar
Default
Thanks for the help guys. I called BB&T today and they also gave me the same answer as everyone else.
Looks like my engine is ready to run , just need some good weather now !!! It wont be long.
Resources saved on this page: MySQL 2.35%
