what rpm difference will i see from 410 gear to 373 - Yellow Bullet Forums
Old 10-18-2009, 12:05 PM   #1
juice
Default what rpm difference will i see from 410 gear to 373
i have 410 gears in my car now and its going threw at close to 8000. want to switch to 373s. any idea what that would pull rpm down to? thanks for any info
J&E
856-227-8100
juice is offline   Reply With Quote
Old 10-18-2009, 12:10 PM   #2
jakesz28
jakesz28's Avatar
Default Re: what rpm difference will i see from 410 gear to 373
We need to know what size tire you are running to figure it out.
check out this site http://www.tciauto.com/Products/Tech...alculators.asp
8.95 @ 151.60 mph with a 383 LT1
www.gmhightechperformance
jakesz28 is offline   Reply With Quote
Old 10-18-2009, 12:15 PM   #3
juice
m/t et drag 28-10.5s
J&E
856-227-8100
Old 10-18-2009, 12:22 PM   #4
slowstang
slowstang's Avatar
it will drop about 700 rpm
slowstang is offline   Reply With Quote
Old 10-18-2009, 12:22 PM   #5
juice
trans is glide
J&E
856-227-8100
Old 10-18-2009, 12:23 PM   #6
slowstang
slowstang's Avatar
that was assuming it runs the same speed....
Old 10-18-2009, 12:24 PM   #7
slowstang
slowstang's Avatar
Originally Posted by juice View Post
trans is glide
that doesnt matter as long as high gear is 1 to 1 which it is
Old 10-18-2009, 12:27 PM   #8
Uncle Paul
Uncle Paul's Avatar
If you assume it will run the same MPH and the converter will lock the same then
[8000/4.10] * 3.73 = 7278 rpm
[8000/4.10] * 3.90 = 7609 rpm
I'm your Huckleberry,,,,
http://www.northernchateau.com/
Uncle Paul is offline   Reply With Quote
Old 10-18-2009, 12:35 PM   #9
juice
cool thanks for info. the 373s is what i want then. plan on uping the shot by 100hp after gear change. thanks again ROB
J&E
856-227-8100
Old 10-18-2009, 12:51 PM   #10
slowstang
slowstang's Avatar
no problem
Old 10-18-2009, 10:11 PM   #11
1 quick z
1 quick z's Avatar
I'm planning on swapping my 4.10's for 3.73's also. I'm thinking I'll be able to turn the nitrous on sooner, and some time in the relatively near future, have Steve hook me up with two annular IS foggers and actually leave on a small shot and turn another one on asap.
No fear No doubt All in Balls out!!!
1 quick z is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Resources saved on this page: MySQL 2.30%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
