Buick 350 SB Stock Appearing Build Questions - Yellow Bullet Forums
Old 01-08-2012, 05:59 PM   #1
Crossbreed383
Crossbreed383's Avatar
Default Buick 350 SB Stock Appearing Build Questions
Putiing together a stock looking 350 buick small block
Need to use factory manifolds due to no headers are available for my chassis(73 Apollo)
Just bought 1 owner 75k 73 Apollo
Looking to have fun with it as a driver with a little extra kick
Its an original 350 2 barrel car
I purchased a fresh 350 motor with converter from somebody that came with 2 cams
Wondering about cam choice and possible mods for these exhaust manifolds
Engine combo is
350 .030 over
3.900"stroke
TRW-10.5 compression forged pistons
Kenne Belle oiling mods
Mildly ported 68 factory heads w stock valve sizes(bowl heavily ported along with runner work and some chamber cleanup/deshrouding)
2-1/2 exhaust- mandrel bent w h-pipe and Dynomax Superturbos
T/A Performance aluminum dual plane with port matching and plenum work-1 in spacer
Modified 800cfm Quadrajet
3500 stall(came with engine)-TH 350 trans
3.73 gear
3400 pound car
I have 2 cams
1-Ultradyne -239-239 @050 530 lift 108 lobe sep +4
2-Erson cam-232-242@050-545 lift-112 lobe sep +4
Again id like to be able to use headers or maybe make a set down the road,but for now i assume that i will need to use the stock manifolds
This basic combo with the tight 108 cam ran mid 13s in Denver in a 3600 pd Skylark with same converter and addition of headers
Thanks
84' LSX Mustang/Hertz Rent-a Car 5.82@116 w 1.26 60 ft 9.😎😎@ 14X ALL MOTOR at 5700ft of D/A on 275 radials
Combinations that are well thought out and the finances spent where they are best utilized, is why some people's cars run faster, last longer and run with less headaches that those who pick and choose their parts by a poll...After all, there are tons of internet racers but only a select few who actually have results.
Crossbreed383 is offline   Reply With Quote
Old 01-08-2012, 06:44 PM   #2
paul c
paul c's Avatar
Default Re: Buick 350 SB Stock Appearing Build Questions
try v8buick.com good buick web site and has a section for small blocks.
paul c is offline   Reply With Quote
Old 01-08-2012, 09:11 PM   #3
Crossbreed383
i tried to register there but it wont ever send a activation email back?
Old 01-08-2012, 10:19 PM   #4
TomGS72
TomGS72's Avatar
Try again.....best info on Buicks is there.
TomGS72 is offline   Reply With Quote
Old 01-08-2012, 11:10 PM   #5
Crossbreed383
I can keep trying
Maybe somebody with an account can messge a moderaotr for me?
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Resources saved on this page: MySQL 3.45%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
