Is there a trick to keeping them locked . Door closed and lock the latch. After the run the door has pulled over the tube and latch is still locked. Anyone have this happen to them before . Not sure what to do now.
Sometimes you need to make sure the latch is really getting in behind the small 1/4" tube, and is "vertical" behind the tube when latched. Alot of times, with rounded windows and the angle at which the 1/4" tube is mounted, it will pull the window in, but realistically, its not BEHIND the 1/4" tube. I hope this makes sense...sort of hard to describe with words.
They should keep the windows held in. How about a pic of your door and window frame area
Related Threads
Yellow Bullet Forums
23.7M posts
139.6K members
Since 2005
