I recently purchased a used PG that was behind a BB Ford and after tearing it apart I found it has a 1.76 gear set and a turbo spline input that is 12 5/8 in length. Is this a multi-shaft or uni-shaft, or did someone run the wrong length? Is there a way to Id the shaft?
Thanks for any help!!
