Hello
I have cal tracs on my car and I set them up like calvert said ( have a person in the car turn it till the stop touches the spring then go a 1/4 turn for preload).I have it in the hole above the bottom one.What changes can I make If i put more preload what does that do and if I have less preload what will that do and if I change it to the bottom hole what will that do.
Just curious to what you guys have experienced before I make some changes
Thank you
John
Thank you
John
