12-15-10 1. General a. Class description: Outlaw Pro Mod is a heads-up maximum effort class for all vehicles bearing drivers and passengers doors. b. Designation: OPM Followed by permanent number. c. Format: 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. auto start is in effect. Time Out is 7 seconds d. Burn Out: Over the line burn outs are allowed (and encouraged). e. Qualifying: Every attempt will be made to initially qualify cars in the lane you wish. Due to time restraints if single lines form cars will be dispersed every other car to open lane. Run lane will be marked on stage ticket. It is mandatory to alternate lanes after initial qualifying pass. Lane choice goes to higher qualifier first round, and then the faster car from previous round. f. Scales: After qualifying all participants must pass over scales your run is validated at this time. In Eliminations you must pass over scales if you have won. If a car fails to make weight the opponents is reinstated, if opponent’s car is of legal weight. It is the responsibility of a competitor to verify his / her weight before run. g. Call to Lanes: Three calls to the lanes will be made. If car is not ready to compete with diver belted in when class is called to the starting line, opponent will be granted a competition bye. h. Staging lanes: Cooling will be allowed in the staging lanes. Cooling must be self-contained on a cart. No expulsion of ANY liquids is allowed in the lanes. Please be courteous to your lane neighbors. When not in the lanes your equipment must be secured away from lanes in designated area. It is YOUR responsibility to know where this designated spot is. i. Bye Run: All vehicles must take the tree and run down the track to be considered a win. j. Waste Oil: Collection centers are provided throughout the pits. Waste oil must be dumped in these bins. Contaminated oil (CONTAMINATION = ANYTHING BUT PURE ENGINE OIL). Must be taken with you when you leave. k. Contingency: It is the competitor’s responsibility to fill out a contingency form and have it verified at the scales. Competitor then turns contingency form in at pay out. l. Pay Out: Payout is located second floor of tower second door on left. m. General NHRA Rules: This is an NHRA race and all vehicles will adhere to NHRA rule book and its latest addendums. n. Driver: Must hold a Current and Valid NHRA Competition License appropriate to type of car, ET and speed. o. Disputes: Starter, tech and or Race directors’ decision is final. p. Clarification: All clarification must be submitted in email form to indytech@nhra.com. No phone calls.
2. Body: Steel, aluminum, fiberglass and carbon fiber bodies and body parts are allowed as long as the car retains its original appearance and profile. Wheel well openings can be modified for tire clearance. The drivers and passenger doors must be fully operational and must open from the outside.
3. Engine: Any Combination allowed.
4. Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs.
5. Transmission: Any type no direct drives.
6. Fuel: No Nitromethane, polypropylene, hydrazine
7. Suspension: Must have working shocks any modifications may be made to suspension.
8. Chassis: Must hold current NHRA cert appropriate for et, speed and weight.
9. Weight: a. Naturally Aspirated: No minimum b. Small Block Nitrous Assisted : 2100 pounds c. Nitrous Assisted: 2,400 pounds d. Supercharged 2,500 Pounds e. Turbo: 2,600 pounds
1. 12-15-10 2. General: a. Class description: Ultimate Dragster is a heads-up maximum effort class for dragsters and altered's with the limiting factor being 10.5 W tires. b. Designation: U/D Followed by permanent number. c. Format: 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. Auto start is in effect. Time Out is 7 seconds d. Burn Out: Over the line burn outs are allowed (and encouraged). e. Qualifying: Every attempt will be made to initially qualify cars in the lane you wish. Due to time restraints if single lines form cars will be dispersed every other car to open lane. Run lane will be marked on stage ticket. It is mandatory to alternate lanes after initial qualifying pass. Lane choice goes to higher qualifier first round, and then the faster car from previous round. f. Call to Lanes: Three calls to the lanes will be made. If car is not ready to compete with diver belted in when class is called to the starting line, opponent will be granted a competition bye. g. Staging lanes: Cooling will be allowed in the staging lanes. Cooling must be self-contained on a cart. No expulsion of ANY liquids is allowed in the lanes. Please be courteous to your lane neighbors. When not in the lanes your equipment must be secured away from lanes in designated area. It is YOUR responsibility to know where this designated spot is. h. Bye Run: All vehicles must take the tree and run down the track to be considered a win. i. Waste Oil: Collection centers are provided throughout the pits. Waste oil must be dumped in these bins. Contaminated oil (CONTAMINATION = ANYTHING BUT PURE ENGINE OIL). Must be taken with you when you leave. j. Contingency: It is the competitor’s responsibility to fill out a contingency form and have it verified at the scales. Competitor then turns contingency form in at pay out. k. Pay Out: Payout is located second floor of tower second door on left. l. General NHRA Rules: This is an NHRA race and all vehicles will adhere to NHRA rule book and its latest addendums. m. Driver: Must hold a Current and Valid NHRA Competition License appropriate to type of car, ET and speed. n. Disputes: Starter, tech and or Race directors’ decision is final. o. Adjustment: If a particular combination is creating conditions that are detrimental to the class, adjustments may be made at any time. p. Clarification: All clarification must be submitted in email form to indytech@nhra.com. No phone calls.
3. Engine: Any combination Permitted
4. Fuel: No Nitromethane, polypropylene, hydrazine
5. Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs. 6. Transmission: Any type no direct drives.
7. Chassis: Must hold current NHRA cert appropriate for ET, speed and weight.
8. Traction Control: Is not allowed. All actions must be pre-set before run. Limited to analog, MSD 75301 MSD 7530T. Six Shooters allowed.
9. Tires: Must run on 33 X 10.5W Must be approved tire. a. Must run bead locks b. Approved tires i. Goodyear D2899 ii. Hoosier 18331, 18335 iii. Mickey Thompson 3068W, 3069W, 3169W
10. Weight Minimums: a. 4- or 6-cylinder Dragsters i. N/A: 1300 pounds ii. Nitrous assisted: 1550 pounds iii. Supercharged or turbocharged: 1650 pounds b. SB Dragster i. N/A: 1500 1550 pounds ii. Nitrous Assisted: 1650 pounds iii. Supercharged or turbocharged: 1750 pounds c. BB Dragster i. N/A: 1550 1600 pounds ii. Nitrous assisted: 1800 pounds iii. Supercharged or turbocharged: 1900 pounds d. 4- or 6-cylinder Altered’s 140” or Less front engine i. N/A: 1300 pounds ii. Nitrous assisted: 1550 pounds iii. Supercharged or turbocharged: 1650 pounds e. SB Altered’s 140” or Less front engine i. N/A: 1500 pounds ii. Nitrous Assisted: 1600 pounds iii. Supercharged or turbocharged: 1700 pounds f. BB Altered’s 140” or Less front engine i. N/A: 1550 pounds ii. Nitrous assisted: 1750 pounds Supercharged or turbocharged: 1850 pounds
1. 12-15-10 2. General : a. Class description: Limited Street is a heads-up class for all types of vehicles from 60's muscle cars to late model automobiles. b. Designation: LS Followed by permanent number. c. Format: 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. Courtesy staging and auto start is in effect. Time Out is 10 seconds d. Burn Out: Over the line burn outs are allowed in Limited. e. Qualifying: Every attempt will be made to initially qualify cars in the lane you wish. Due to time restraints if single lines form cars will be dispersed every other car to open lane. Run lane will be marked on stage ticket. It is mandatory to alternate lanes after initial qualifying pass. Lane choice goes to higher qualifier first round, and then the faster car from previous round. f. Scales: After qualifying all participants must pass over scales your run is validated at this time. In Eliminations you must pass over scales if you have won. If a car fails to make weight the opponents is reinstated, if opponent’s car is of legal weight. It is the responsibility of a competitor to verify his / her weight before run. g. Call to Lanes: Three calls to the lanes will be made. If car is not ready to compete with diver belted in when class is called to the starting line, opponent will be granted a competition bye. h. Staging lanes: Cooling will be allowed in the staging lanes. Cooling must be self-contained on a cart. No expulsion of ANY liquids is allowed in the lanes. Please be courteous to your lane neighbors. When not in the lanes your equipment must be secured away from lanes in designated area. It is YOUR responsibility to know where this designated spot is. i. Bye Run: All vehicles must take the tree and run down the track to be considered a win. j. Waste Oil: Collection centers are provided throughout the pits. Waste oil must be dumped in these bins. Contaminated oil (CONTAMINATION = ANYTHING BUT PURE ENGINE OIL). Must be taken with you when you leave. k. Contingency: It is the competitor’s responsibility to fill out a contingency form and have it verified at the scales. Competitor then turns contingency form in at pay out. l. Pay Out: Payout is located second floor of tower second door on left. m. General NHRA Rules: This is an NHRA race and all vehicles will adhere to NHRA rule book and its latest addendums. n. Driver: Must hold a Current and Valid NHRA Competition License appropriate to type of car, ET and speed. o. Disputes: Starter, tech and or Race directors’ decision is final. p. Clarification: All clarification must be submitted in email form to Indytech@nhra.com. No phone calls.
3. Body: a. General: The car must retain its original appearance and profiles. Roof and rear quarters must be steel. After market fiberglass wings and spoilers are permitted. b. All nitrous bottles to be safety vented pop off to outside the vehicle. c. Lexan windows allowed. 4. Lettering / Decals: Car lettering & Decals are allowed on all windows. Must run Series Decal. Decals are allowed on car but must retain a street image. The intent is this rule is the cars should look street legal, not like a heavy contingency race car. 5. Engine: Any engine combination allowed. Motor plates and solid mounts allowed.
6. Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs. 7. Mufflers: Not required. Exhaust may exit underneath car or out the front fenders. 8. Transmission: Any type automatic or OEM manual transmission allowed. 9. Front Chassis/Suspension: a. Stock front frame rails and suspension required. b. Aftermarket control arms and bushings allowed as long as they bolt in stock locations. c. Rack and pinion steering allowed. d. Aftermarket tubular control arms, coil over kits, or OEM front strut retrofits are permitted. But must be a direct bolt on, no welding modifications permitted. e. Aftermarket bolt in sub-frame allowed. Must bolt in unaltered stock OEM mounting locations. 10. Rear Chassis/Suspension: a. Any type rear suspension allowed. b. Must have factory appearing dashboard. c. Firewall must be retained and in stock location. d. Wheelie bars allowed (add 150 Lb.).
11. Rear Tires: 29.5" x 10.5 non W or 315 drag radial or smaller. a. Up to 34.5 x 16 large tire combinations allowed by adding 150 LBS (includes wheelie bar increase). 12. Weights: a. SB N/A 2350lbs (2500 with bars or big tires) b. BB N/A 2600 lbs. (2750 with bars or big tires) c. SB NOS 2500 lbs. (2650 with bars or big tires) d. BB NOS 3100 lbs. (3250 with bars or big tires) e. SB Turbo 3100 lbs. (3250 with bars or big tires) f. SB Twins Supercharger / Turbo's 3150 lbs. (3300 with bars or big tires) g. SB Supercharger 3100 lbs. (3250 with bars or big tires) h. BB Supercharger 3300 lbs. (3450 with bars or big tires) i. BB Single Turbo 3300 lbs. (3450 with bars or big tires) j. BB Twins Supercharger/Turbos 3350 lbs. (3500 with bars or big tires) k. Leaf Springs - Subtract 100lbs
Can someone Please explain to me what a 34.5x16 tire has to do with Limited Street??? Limited Street has always been a 29.5x10.5 non W and in the last few years the 315 Drag Radial was added. To let the 34.5x16 tire in this class is ridiculous!!! 150lbs for BARS??? What a joke!!! Count me the hell out!!!
1. 12-15-10 2. General: a. Class description: True Street is a heads-up class for all types of vehicles from 60's muscle cars to late model automobiles. b. Designation: TS Followed by permanent number. c. Format: 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. Courtesy staging and auto start is in effect. Time Out is 7 seconds d. Burn Out: Over the line burn outs are allowed in True Street. e. Qualifying: Every attempt will be made to initially qualify cars in the lane you wish. Due to time restraints if single lines form cars will be dispersed every other car to open lane. Run lane will be marked on stage ticket. It is mandatory to alternate lanes after initial qualifying pass. f. Scales: After qualifying all participants must pass over scales your run is validated at this time. In Eliminations you must pass over scales if you have won. If a car fails to make weight the opponents is reinstated, if opponent’s car is of legal weight. It is the responsibility of a competitor to verify his / her weight before run. g. Call to Lanes: Three calls to the lanes will be made. If car is not ready to compete with diver belted in when class is called to the starting line, opponent will be granted a competition bye. h. Staging lanes: Cooling will be allowed in the staging lanes. Cooling must be self-contained on a cart. No expulsion of ANY liquids is allowed in the lanes. Please be courteous to your lane neighbors. When not in the lanes your equipment must be secured away from lanes in designated area. It is YOUR responsibility to know where this designated spot is. i. Bye Run: All vehicles must take the tree and run down the track to be considered a win. j. Waste Oil: Collection centers are provided throughout the pits. Waste oil must be dumped in these bins. Contaminated oil (CONTAMINATION = ANYTHING BUT PURE ENGINE OIL). Must be taken with you when you leave. k. Contingency: It is the competitor’s responsibility to fill out a contingency form and have it verified at the scales. Competitor then turns contingency form in at pay out. l. Pay Out: Payout is located second floor of tower second door on left. m. General NHRA Rules: This is an NHRA race and all vehicles will adhere to NHRA rule book and its latest addendums. n. Driver: Must hold a Current and Valid NHRA Competition License appropriate to type of car, ET and speed. o. Disputes: Starter, tech and or Race directors’ decision is final. p. Clarification: All clarification must be submitted in email form to Indytech@nhra.com. No phone calls.
3. Body: a. General:The body must retain its original appearance, profiles, and dimensions. Factory roof and quarter panels must be used. Aftermarket fiberglass replacement panels are limited to hood, front fenders, doors, deck lids, and bumpers only. All front ends must be of factory dimensions and cannot be stretched. Aftermarket wings and spoilers are permitted. Complete stock appearing front and rear bumpers are required. A hood must cover the entire induction system.
b. Lettering Decals: Must run Series Decal.
c. Lighting: Functional headlights, taillights and brake lights required. All headlights, brake lights, marker lights, etc. must be on car and not removed for any reason.
d. Interior:Factory appearing dashboard, door panels, and driver seat is required. Bare inside frame of car cannot be exposed. Aftermarket steering column is permitted.
e. Windshield/Windows: OEM glass or Lexan windows are permitted. No visible fasteners. Tint must be light enough for track personnel to easily see driver.
4. Chassis: a. Complete stock chassis and frame rails must be retained. b. Back-halved cars are not permitted. c. Front core support may be modified or removed. d. Aftermarket bolt-on replacement front K-members are allowed (if front shocks bolt to K-member then they must be in factory location). e. Mini tubs are allowed. f. Rear frame rails may be notched for clearance. g. Roll cage must have appropriate NHRA certification for weight and speed and certification must be current.
5. Engine: a. Turbocharger: Single 88MM opening of turbo charger and will be checked at inducer by go -no- go. Mid-frame 88’s and any larger turbo that is reduced will be equalized by weight addition. Any type intercooler is permitted. Cannot combine with nitrous oxide. b. Superchargers: Cog or gear driven superchargers are permitted. Any type intercooler is permitted. Cannot combine with nitrous oxide. Roots superchargers are limited to an 8-71; Centrifugal supercharger is permitted but limited to a maximum F-1 configuration or equivalent for base weight. Super charger must have inducer equal to 3.75” or will receive weight. Supercharger cannot combine with nitrous. c. Nitrous Oxide:Small block is permitted to run any type multi-stage nitrous system. Big blocks are limited to a single stage nitrous system. d. Oiling system: Dry sumps are permitted on all cars. e. Fuel: Gasoline Ethanol Methanol. No polypropylene, Nitromethane, hydrazine.
6. Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs. 7. Transmission: a. Any style transmission allowed 8. Electronics: a. Electric shifters or air shifters are prohibited. 9. Exhaust: a. Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders. 10. Suspension: a. General: Direct replacement components such as: front control arms, rear control arms, front coil over shocks, and rear coil over shocks are permitted. Aftermarket rack and pinion steering allowed. b. Rear Suspension: Rear leaf springs, springs, shocks, and coil-overs may be moved to accommodate tire clearance, and do not need to be mounted in stock location. Bolt-on or welded sub-frame connectors, rear sway bars, are permitted on all cars. c. Torque arms: Are only permitted on cars that were originally equipped from factory with it. d. Four links: Are prohibited on all cars. e. Ladder Bars: Ladder Bars are permitted. f. Wheelie bars: Are prohibited on all cars.
11. TIRES: a. Size / Style All cars with power adder must compete on a Drag Radial type tire with the following sidewall designation 275/60/15 (OR) 28.0” x 10.5 Slick (add 50lbs). No “W” Tires are permitted. i. Naturally aspirated cars are permitted to run a 29.0” x 10.5” slick, no “W” tires permitted.
12. Weight: TRUE STREET a. Minimum Weights: All weights include the driver. b. At initial tech in inspector will view combination and calculate weight, Inspector will place on YOUR tech card combination weight. This weight will be placed on your right side passenger window and sealed. Driver / Owner will verify correct combination is on window for scale operator and sign tech card that combination is verified. i. Naturally Aspirated SB 2500 lbs. ii. Naturally Aspirated BB 2750 lbs. iii. Nitrous (small block) 2900 lbs. iv. Nitrous Big Block 3250 lbs. v. Small Block Forced: 1. Single Supercharger (3.75 Inducer) 3100 2. 88mm Turbo at Inducer 3100 a. Mid Frame 88MM 3200 b. Reduced turbo or super charger 3200 vi. Big Block: 1. Single Supercharger (3.75 Inducer) 3300 2. 88mm Turbo at Inducer 3300 a. Mid Frame 88MM 3400 b. Reduced turbo or super charger 3500 vii. ** 28.0” x 10.5 Slick (No “W”) add 50LBS
1) 12-15-10 2) General: a) This class contests the ultimate in street-legal motorcycles. Created to legitimize illicit street racing, Rage Pro Street is reserved for stock-appearing motorcycles with unlimited engine modifications. All bikes must be street legal with VIN tag, self-starting with motorcycle engines only. b) Format: 1/4 mile heads-up class run on a .400 pro tree with a pro ladder. Auto start is in effect. Time Out is 7 seconds c) Frame must be OEM, frame modifications permitted as long as factory appearance is retained (I.E. cutting of seat rails, short necking...) d) Engine and frame swap permitted as long as same manufacture. (Suzuki/ Suzuki or Kawasaki/Kawasaki) e) Must have minimum one functional front brake caliper and rotor and the same for the rear brakes. f) Must have functional headlight and taillight. OEM preferred but not required. g) Aftermarket lightweight front-ends, swing arms and wheels permitted. Solid prohibited h) NHRA Legal Chain guard is required. i) NO wheelie bars! j) 2 inch ground clearance minimum. k) Tether required. l) All engines must be self-starting and utilize onboard, OEM-style starting systems m) All weights include both the bike and rider, and will be taken at the conclusion of the run. n) All participants in Rage Pro Street Bike must hold a current and appropriate NHRA racing license. o) All rules disputes will be decided by Tech and or Race Director p) Factory headlight systems matching the bike model must be used. All of the original factory glass or plastic lenses must be used, may not be painted or wrapped, and must be mounted in the original location in the front fairing (or headlight bucket on non-faired bikes). Non-fairing bikes must have the headlight bucket mounted in factory location. All components which are part of the original beam generating and reflecting system, and are visible from the outside of the bodywork, must be retained, and may not be modified in any manner visible from the outside. These components include reflectors, secondary lenses, diffusers, bulb sockets, and bulbs. All such components of both the low-beam and high-beam systems must be retained, even if that system is not in use. Required components may be mounted in any suitable manner. Any modification of the mounts, housing, or non-visible areas of the lenses, reflectors, and other required components is permitted. However, lighting system must be enclosed to prevent the escape of light from behind the fairing or bucket. q) All entrants must have a functioning taillight system, with operational tail and brake lights. Factory taillights are highly recommended. Non-factory tail lights must emit red light, and must be sufficiently bright to see at end of race track from starting line. r) If any combination shows a clear advantage it is the discretion of O’Reilly Raceway parks tech department and or race director to change any class accordingly at an event. s) Every attempt will be made to post any new and additional changes 14 days before an event. t) Any questions can be sent to indytech@nhra.com 3) General Safety: a) All riders must have full leathers. If two piece they must zip together. All riders must have a SNELL 2000 or higher full-face helmet with shield, leathers gloves, and shoes above the ankle. All motorcycles and riders must pass NHRA safety inspection. Ballistic blankets are recommended but are not required. Tether kill switches required on all entrants. Kill switch, when activated, must disable ignition, fuel pump(s) and nitrous system solenoids. 4) Turbos a) 68" Wheelbase maximum b) Rear tire - DOT only c) Transmission - Hand clutch only (no sliders or auto trans) d) Single turbo only - no nitrous e) Intercoolers, after coolers, water injection permitted f) Fuel - Gasoline only g) Weight - 685 pound minimum bike and rider h) 2 Step launches not allowed
5) Nitrous or Super Charged a) 75" Wheelbase maximum b) Rear tire - DOT c) Transmission - Slider and auto trans are allowed Maximum of two stages of nitrous allowed d) Fuel injection or carburetor allowed e) Fuel - Gasoline only f) Weight – over 1L 570 Under 1L No Min g) 2-Step launches allowed
6) All Motor (N/A) a) Any wheelbase allowed b) Rear tire - DOT or up to a 7" slick c) Transmission - Slider and auto trans are allowed d) Fuel injection or carburetor allowed e) Fuel - Gasoline, alcohol, or Nitromethane (30% Nitromethane max blend) f) Weight - No minimum g) 2-Step launches allowed
7) V-Twin a) Any wheelbase allowed b) No Minimum Weight c) No Cubic Inch Limit d) Multiple Power adders allowed e) 7 Inch Slick allowed f) Two Step allowed g) Aftermarket frames may be approved for use in this class, but their concept, appearance, and design must be approved prior to any construction. h) Fuel - Gasoline, alcohol, or Nitromethane (30% Nitromethane max blend)
1) General a) Class description: Index is a heads-up class for all types of vehicles from early models to late model automobiles and motorcycles. b) Designation: IDX 9.0 or 10.0 Followed by permanent number. c) Format: 1/4 mile heads-up class run on a .400 pro tree with a pro ladder. Courtesy staging and auto start is in effect. Time Out is 7 seconds d) Burn Out: Over the line burn outs are not allowed in Index classes. e) Qualifying: Every attempt will be made to initially qualify cars in the lane you wish. Due to time restraints if single lines form cars will be dispersed every other car to open lane. Run lane will be marked on stage ticket. It is mandatory to alternate lanes after initial qualifying pass. Lane choice goes to higher qualifier first round, and then the faster car from previous round. f) Scales: N/A g) Call to Lanes: Three calls to the lanes will be made. If car is not ready to compete with diver belted in when class is called to the starting line, opponent will be granted a competition bye. h) Staging lanes: No Cooling is allowed in the lanes i) Bye Run: All vehicles must take the tree and run down the track to be considered a win. j) Waste Oil: Collection centers are provided throughout the pits. Waste oil must be dumped in these bins. Contaminated oil (CONTAMINATION = ANYTHING BUT PURE ENGINE OIL). Must be taken with you when you leave. k) Contingency: It is the competitor’s responsibility to fill out a contingency form and have it verified at the scales. Competitor then turns contingency form in at pay out. l) Pay Out: Payout is located second floor of tower second door on left. m) General NHRA Rules: This is an NHRA race and all vehicles will adhere to NHRA rule book and its latest addendums. n) Driver: Must hold a Current and Valid NHRA Competition License appropriate to type of car, ET and speed. o) Three out system for non NHRA cert cars or non-licensed drivers going quicker than 9.99 i) Not three per event three, period. p) Disputes: Starter, tech and or Race directors’ decision is final. q) Clarification: All clarification must be submitted in email form to Indytech@nhra.com. No phone calls. 2) Body a) Heads-Up Index classes are reserved for full-bodied cars with full fenders, Hoods, grille, top, windshield, and functional doors. 3) Bikes a) Must be street legal with working head light and tail light. b) Must have current registration and plate. c) No Wheelie bars d) Full leathers required e) Kill tether required 4) The 2 classes are as follows: a) 9.00 Heads-Up index (.400 Pro Tree) 16 Car Field b) 10.00 Heads-Up index (.400 Pro Tree) 16 Car Field c) For rules and regulations refer to the following websites for the appropriate E.T. and vehicle type being used
5) ELECTRONICS RULES : a) Delay boxes and/or timed throttle stops prohibited b) Mechanical type throttle stops permitted. Any adjustment during run prohibited c) Timers of any kind associated with, but not limited to, fuel and/or nitrous delivery, d) Throttle control, vehicle performance criteria, etc. are strictly prohibited e) Transmission brakes permitted 6) Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs. 7) Tires a) Slicks or drag radials must be used.
1) General a) Class description: Open Comp Dial In Staggered of vehicles from early models to late model automobiles only. b) Designation: OC Followed by permanent number. c) Format: 1/4 mile dial in gambler style class run on a .500 sportsman tree with a pro ladder. Courtesy staging and auto start is in effect. Time Out is 7seconds d) Burn Out: Over the line burn outs are not allowed in Open Comp. e) Qualifying: Every attempt will be made to initially qualify cars in the lane you wish. Due to time restraints if single lines form cars will be dispersed every other car to open lane. Run lane will be marked on stage ticket. It is mandatory to alternate lanes after initial qualifying pass. Lane choice goes to higher qualifier first round, and then the faster car from previous round. f) Scales: N/A g) Call to Lanes: Three calls to the lanes will be made. If car is not ready to compete with diver belted in when class is called to the starting line, opponent will be granted a competition bye. h) Staging lanes: No Cooling is allowed in the lanes i) Bye Run: All vehicles must take the tree and run down the track to be considered a win. j) Waste Oil: Collection centers are provided throughout the pits. Waste oil must be dumped in these bins. Contaminated oil (CONTAMINATION = ANYTHING BUT PURE ENGINE OIL). Must be taken with you when you leave. k) Contingency: It is the competitor’s responsibility to fill out a contingency form and have it verified at the scales. Competitor then turns contingency form in at pay out. l) Pay Out: Payout is located second floor of tower second door on left. m) General NHRA Rules: This is an NHRA race and all vehicles will adhere to NHRA rule book and its latest addendums. n) Driver: Must hold a Current and Valid NHRA Competition License appropriate to type of car, ET and speed. o) Three out system for non NHRA cert cars or non-licensed drivers going quicker than 9.99 i) Not three per event three, period. p) Disputes: Starter, tech and or Race directors’ decision is final. q) Clarification: All clarification must be submitted in email form to Indytech@nhra.com. No phone calls. 2) Clarification a) 1/4 Mile, Index Dial-In Staggered Tree, .500 Pro Tree, 16 Car Field b) Door Cars only 10.00 - 12.99 c) No delay boxes allowed d) Tires must be slicks or drag radials e) Qualifying based on reaction time, there will be two rounds f) Indexes are computed by taking your quickest pass and subtracting .10 from it. That becomes your dial in for the rest of the race g) Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs.
Looks like l/s has an opening for just about any car that would want to race" big tires vs small tires bars no bars multiple power adders " If you say you wanted to race these rules let in tons of combo's if your not there you are flat out scared.
I like the idea of giving everyone a chance to race and leaving room to tweak the rules as needed for combos ,I wil be spreading the word and I know there will be cars from illinois coming!
Well - it excludes full chassis cars (me). But other than chassis cars, seems like you've got a place to race. I might try to add some weight and do high gear only passes to slow it down for the 9.0 index class. I made one pass this year like that and ran 8.900. A little weight or a little timing taken out and I might be able to slow down some more. It's certainly worth a try.
I think true street should allow any "bolt in" style rear suspension. So long as it bolts into the factory location.
Other than that, I'm happy.
I don't see any weight limits for us 4 banger guys. I'll likely be the only one there in that class, so I'm not asking for special treatment, just wondering.
But it's allowed in True Street, where 4-links aren't, but it isn't allowed in Limited Street where 4-link are allowed???
That just doesn't make sense. Not arguing, I just think that was an over site. I'm sure the rules will still need tweaked a bit. No one nails them the first time out.
The only question I have is this is 1/8th mile racing why does a turbo weigh 100 more than a supercharged car? Has anyone looked at the 1/8th mile E.T. of a turbo car and compare it to the supercharged cars in NHRA? Everything else looks good.
I do agree with Bill on this one. Pro Mod Turbo cars really never ran well to the 1/8. If it was me making the rules I would make them the same and adjust if needed down the road.
The only other rule I see is in Limited Street / 315 Radial / 10.5 that I question.
Why would their only be a 50lb weight savings between a single turbo and a twin turbo set-up. I think 100 would be best but this would be splitting hairs.
Great job on getting it out for everyone to see and now I just hope the racers support the event's. Over time this could be a really great program.
I'm excited to be able to race somewhere that I don't have a 5 hour ride to get to and also can go and watch some great Outlaw stuff close to my house. Maybe this will help bring some more of these style cars to the mid west and help Outlaw Racing grow.
Related Threads
Yellow Bullet Forums
23.7M posts
139.6K members
Since 2005
