Questions regarding TRZ PHB/ARB install in 4-gen F-body
731 views 0 replies 1 participant last post by  sped
This is a TRZ PHB/ARB installed in 4-gen Trans Am. I have the PHB/ARB installed, the rearend squared up and the car strung. Thought I would ask a few questions before welding the end link brackets to the rearend.
1. How much adjustability should I have in the end links prior to welding the tabs to the rearend? Should lengthen the rod ends a few turns for neutral?
2. The "arms" on the ARB should be angled slightly up (running uphill toward the front of the car), is 10 degrees about right? Should it be more or less?
3. The end links should be as vertical as possible correct? Side to side and front to back?
Thanks guys.
