Anything gonna change??????
I'm trying to grasp exactly what your motive is with this.Personally, I like the current rules and wouldnt like to see drastic changes. Clarification on the tire rule would be great, IMO....because of the issue this year.
Wheelie bars: Have the drivers VOTE on it. They own the cars and are responsible for fixing them. I say the the driver speak. Whatever the outcome, is the outcome.
I honestly think the only "rule" that needs addressing is the iintake manifold. There was plenty of tunnel ram manifolds this year, and I would bet their will be more next year. IMO, they have an advantage and should carry weight. I dont think cast tunnel rams, with a single top, were the original intent of the rule (but that is just my opinion). I would be open to sheet metal or "whatever".....as long as its defined and easily verified (tech'd).
As I stated before, this is a one night show. Milan does not have the time (or capability) to police the phuck out of this class. The rules need to be simple (like they are now), with some better clarification on a few.
Thanks for the props from all of Us "Little Guys"Unfortunately, so called little guys(I'd rather call them the smart ones) won't keep up in any heads up class format, regardless of rules. It has always been that way especially in a normally aspirated class. No weight penalties, tire limitations, weight breaks, etc... will allow a little guy to out run a big spender. You can't control other peoples wallets.
As for getting out of hand, what do you call 100k + cars running 8.20's to 8.40's for the last 4 years?
You can't rule restrict progression of a class. The rules will actually drive the costs up, and the class will not slow down at all.
You're worn out because you work all the time. Work by day, build engines all night. When you get a free minute, you're running off with your family somewhere. Honestly, I dont know how you do it!I'm worn out. Just settle on the rules and I'll fit it in. Don't much care what they are at this point, which is why I personally don't want any changes. If I wanted to go race a class, it would be Pro Stock..... Milan is suppose to be for fun.... not worrying about penalties and weight breaks.
:-DHey I want a participant ribbon for very one that qualifies...
There are no losers....
