#1
Dec 15, 2013
Tdc for my engine is nowhere near the Tdc mark on the balancer. Tdc is pointing to the 0° mark.I'd this normal? I'm installing the msd timing tapes right now, so does this even matter?
See less
See more
1
#2
Dec 15, 2013
Assuming you found true top dead with a piston stop, the pointer should point to the 0* mark.
#3
Dec 15, 2013
Is this a joke?
0 degrees is TDC.
Vertical TDC is just that, the line will be at 12 O'clock. It is just an extra line, not meant to line up with the pointer.
#4
Dec 16, 2013
Yep, all is good here ..... I would put the tape on it anyway if you can see it better than the markings on the dampner. That zero is TDC
#8
Dec 16, 2013
Or horizontal TDC, or tangential TDC. Some people like tangenital TDC.
0
#6
Dec 16, 2013
Why use tape? Pointer is adjustable and balancer is already marked. Put piston at true TDC and adjust the pointer to show -0-
#7
Dec 16, 2013
i like the tapes, my rattler balancer marks are faded bad, but every tape flys off at the track.
#10
Dec 16, 2013
a friend of mine puts the tape on and clear coats it, so it doesn't come off.
0
#9
Dec 16, 2013
I put shipping tape over my timing tape seems to hold it on a lot longer. i had to put a timing tape on my ati balancer due to faded marks
#11
Dec 16, 2013
Good jokes bitches.
this is a professional products balancer and I didn't trust it. Thanks guys. Installed the tape, all is good.
#12
Dec 16, 2013
wtf your pointer is adj, as long as your sure its tdc adj the point to 0 and your good to roll......dont get why people over-complicate shit so much
#13
Dec 16, 2013
x2, just loosen the two allen headed bolts and move the pointer to the zero line and its all good.. no need for tape or overcomplication....
0
#15
Dec 16, 2013
Wow, you're working on this yourself? Wait till you get inside the bitch.
#16
Dec 16, 2013
please tell me he was kidding and forgot the emoticon or JFK
#17
Dec 16, 2013
just did mine today, i was one degree off on pointer. showed 1 more degree advanced then what it was.
#18
Dec 16, 2013
I have even tried super gluing tapes on, still come off. I just use nail polish to mark the TDC mark an my 38 degree mark on balancer...
#19
Dec 16, 2013
Shoot, I just use a Pentel [ball-tip] correction pen to mark initial and full advance.
I know to not douche it down with brake-clean or the pressure washer.
I didn't use a clear coat 'cause I might wanna make a change.
'1st time I have seen a "vertical TDC" marking...
#20
Dec 17, 2013
Never seen a smallblock with the timing tab behind the water pump?
#21
Dec 17, 2013
Mark behind the WP was maybe late 70's to 80's. It was read with some sort of magnetic pick up that fit in a slot/tube and shown on a screen.
