I have a batch fire ECU that I purchased through Yellow Bullet.....I want to use it on a BB Chevy, but I was told it my have a Ford firing order. Can the order be set to Chevy with a lap top?
You will want to change the firing order in the ecu and also make sure the injector harness is setup correctly. I think they have a wiring diagram for the injector harness in the help section of the FAST software.
