Any real world mpg increases with aluminum trailer? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Trailers
Trailers Talk about trailers, upgrades, goodies and towing
Old 05-05-2012, 07:27 PM   #1
94-6spd
94-6spd's Avatar
Default Any real world mpg increases with aluminum trailer?
I'm intersted in real world numbers using a Feather Lite open vs. open steel trailer. Is it worth the initial cost up front?
94-6spd is offline   Reply With Quote
Old 05-05-2012, 11:39 PM   #2
twoodard
twoodard's Avatar
Default Re: Any real world mpg increases with aluminum trailer?
The weight savings is real. I had a 28 ft conventional tag and changed to a 40ft Exiss the total weight difference made it a 1015lbs increase. The price diff is big but I felt in the long term it would be worth it.
Say no to boost! Just bring the Man Shot
special Thanks to. PKRE, MDRC, Induction Solutions, RPM Performance, ProTorque, Sunset Performance
twoodard is offline   Reply With Quote
Old 05-06-2012, 09:01 AM   #3
Prostude
Prostude's Avatar
I switched from a 30' Pace tag to a 40' Exiss last year. Prior to my adding a lounge they were basically the same weight. I am not sure what it weighs now but still light enough to pull with my 2500HD with no problem.
"World's fastest N/A small block Studebaker"
Prostude is offline   Reply With Quote
Old 05-06-2012, 09:29 AM   #4
mrdragster1970
T/S 368E
mrdragster1970's Avatar
If you park outside, and plan to keep it a long time, definitely.
At my shops there were 2 snowmoble trailers parked out side.
You could literally watch the steel one rot away over the years.
The aluminum one is still here, and the steel one was scrapped a few years ago.
Now if you park inside, then you should have zero issues like that, and it might not be worth it??
When I had an open trailer, I parked inside, and after 5 years of racing every W/E,
it looked 100 times better then my friends trailers that sat out side.
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 05-22-2012, 06:53 AM   #5
Lucky3
Lucky3's Avatar
Weight difference will be minimal, cost is significantly higher, no noticeable mpg gain. Resale much better. No rust or corrosion. Save your money for an enclosed !
Lucky3 is offline   Reply With Quote
Old 05-22-2012, 08:36 AM   #6
Sisco 97
Sisco 97's Avatar
While there is some weight savings, you won't see a significant difference in MPG. The aluminum is just less maintenance.
Sisco 97 is offline   Reply With Quote
Old 05-22-2012, 10:06 AM   #7
Firetruck1
draggin' ass
Firetruck1's Avatar
You will have a roughly 1000 pound less trailer for about 2.25 times the amount in price for aluminum versus steel. Unless this 1000 pounds allows your truck to safely tow where it would not on the steel trailer (maybe mid size truck or underpowered), I say no real advantage. If you are wanting to keep it cheap or light, look for a open pit steel trailer, they weigh a few hundred pounds less then a full deck. You can also look for a wood runner open deck trailer, again lighter by another hundred or two pounds. I had a 18 foot steel open pit with wood runner trailer that was about 1600 pounds, damm near what a aluminum trailer weighs.
Michael
Thank you to all who have helped me on my projects:
Dan Neumann Race Cars
Fast Forward Race Engines
FTI Converters and Transmissions
Holeshot Wheels
Jones Racing Products
NRC Motorsports
TRZ Motorsports
“Le Petomane Thruway? Now what'll that a**hole think of next? Does anybody got a dime? Somebody’s gotta go back and get a sh**-load of dimes!”
I have sincere gratitude for gold star families. Thank you
Firetruck1 is offline   Reply With Quote
Resources saved on this page: MySQL 1.11%
