Difference in susp,setup from slicks to DRs - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 04-28-2012, 11:33 PM   #1
BruceO
BruceO's Avatar
Default Difference in susp,setup from slicks to DRs
Im switching from slicks to 275 DRs. only had the car out for a few passes on a totally new combo( went from N20 to turbo) but had slicks. 60d 1.30s which i thought wasn't too bad for a new combo,driver learning a new starting line technic,you know..all new ball game..
so now I'm going with DRs and was wondering what changes i might need for the switch.
right now my setup is
rear Strange Coil overs (single adjust) w/130lb springs.solid hiem joint U/L C/As ,anti roll bar
front Hal single adjustable struts 150lb-14in springs all tube front susp.
besides maybe changing a few parts..does a DR like higher/lower C/G
shorter or longer C/G
tighter or looser front strut setting?
I'm sure not many people making these radials work will share EVERYTHING,but a little help would be appreciated . Thanks
I may not be the best,but when the top 10 get together,they all talk about me..
BruceO is online now   Reply With Quote
Old 04-29-2012, 03:23 PM   #2
BruceO
BruceO's Avatar
Default Re: Difference in susp,setup from slicks to DRs
Also i might add that right now my A/S is at 100% .
Old 04-29-2012, 07:25 PM   #3
Firetruck1
draggin' ass
Firetruck1's Avatar
I will start that virtually every fast shop and tuner/racer swears you must have double adjustable shocks for the rear and it is a very good idea on the front end too.
Michael
Thank you to all who have helped me on my projects:
Dan Neumann Race Cars
Fast Forward Race Engines
FTI Converters and Transmissions
Holeshot Wheels
Jones Racing Products
NRC Motorsports
TRZ Motorsports
“Le Petomane Thruway? Now what'll that a**hole think of next? Does anybody got a dime? Somebody’s gotta go back and get a sh**-load of dimes!”
I have sincere gratitude for gold star families. Thank you
Firetruck1 is offline   Reply With Quote
Old 04-30-2012, 09:36 AM   #4
JeffMcKC
JeffMcKC's Avatar
With 100 % it may need to be a little higher and the shocks need a tighter comp most of the time. It will also show any issues with front ends smoothness of travel. Just think of it being a much smaller window to tune in.
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 04-30-2012, 11:34 AM   #5
BruceO
BruceO's Avatar
OK ,thanks for the replies.
i plan on getting new rear shocks.double adjustable.ill just sell my old single adjustables.
i do have some adjustments on the rear control arms,so i can add a little more AS. does it matter if i get more AS if the connecting points are shorter? i'm guessing i have no choice on that.should the CG be moved up or down or try to keep it the same by moving both the upper and lower C/A or just one ?
Old 04-30-2012, 12:42 PM   #6
holyshift
holyshift's Avatar
I know I have no monster of a car,but when I tightened my strange single adj. Up front it helped the car launch with the more power I was putting down. I think before it was coming up and back down too quick and taking weight off the rear tires. My 2 cents.
Long rod 308,all forged,4r70w with Freak Show Converter,76mm VSracing.com turbo,Steve Taylor PRC Carb.
Yea Dude Racing,Big Kid Racing
Best ET:10.75@123 1.44 60' on the sauce
Ride with me http://youtu.be/IxZnUVjoJbM
http://www.facebook.com/pages/Yea-Du...12933502113677
IBEW Local 129 Apprentice 4th year
holyshift is offline   Reply With Quote
Resources saved on this page: MySQL 1.12%
