Belt issue on SBF 73t crank and 46T upper - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 04-29-2012, 05:35 PM   #1
GregS
GregS's Avatar
Default Belt issue on SBF 73t crank and 46T upper
Anyone else have this problem? My charts show this should work....but there is too much slack in the belt when I adjust the tensioner all the way? 1512 belt....
1988 Ford Mustang LX
Fox Lake, Procharger, FB Glide, AutoFab Race Cars, PCS, FAST XFI and, Harlow Sammons Racing
8.77/157 MPH Best ET/MPH
GregS is offline   Reply With Quote
Old 04-30-2012, 12:20 AM   #2
Fbodykiller
Default Re: Belt issue on SBF 73t crank and 46T upper
You will probably need the 1584 with the larger diameter idler pulley
Fbodykiller is offline   Reply With Quote
Old 04-30-2012, 12:47 AM   #3
Jake
Jake's Avatar
Check that you have the tensioner block (the rectangular block the tensioner bolts to which can be flipped so the dowel and tensioner "axle' bolt can either be up or down) flipped the correct way for enough travel. If so you may need to go to a larger idler pulley.
http://jakesperformancefabrication.com/
Home of the Fastest Stock Suspension Drag Radial Car on Drag Week 2011
THANKS- Steve Morris Engines, Dave W @Procharger, Painted with Powder, Weld Wheel, Strange, TCI ProX, M&M Converter and all the individuals that helped along the way to contribute to our Drag Week BB Power Adder WIN! 7.82@189 on M/T 295's w/ stock suspension at 3600+
Jake is offline   Reply With Quote
Old 04-30-2012, 06:04 AM   #4
GregS
GregS's Avatar
Yea...flipped the block and still cant get it tight. How big is the larger idler pulley? Who has them...and what diameter is the larger one?
Thanks
Resources saved on this page: MySQL 2.38%
