MLS head gasket question?????????? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Trash Or Be Trashed
Trash Or Be Trashed Where the weak are killed and eaten!!!! Vulgar language and nudity may be enclosed!! NWS
Old 04-28-2012, 07:41 PM   #1
Motoimpaired
Motoimpaired's Avatar
Default MLS head gasket question??????????
I'm putting some Cometic MLS head gaskets on my sbf. Should I put them on dry or would a light coat of copper spray be good to use?? Waiting on someone's response while I sit here in the garage.....
Please and thank you...
Say what you want, Ill just use it against you...
Motoimpaired is offline   Reply With Quote
Old 04-28-2012, 07:43 PM   #2
halfpint
halfpint's Avatar
Default Re: MLS head gasket question??????????
I was told dry with a little silicone on the ends, thats how I did mine with no problems
halfpint is offline   Reply With Quote
Old 04-28-2012, 07:45 PM   #3
EXSSIVE
Under Construction
EXSSIVE's Avatar
I spray everything Ive ever done, never heard anyone tell me not to.
AMSOIL DEALER
2000 Camaro SS
Special Thanks To:
NRC Motorsports-Aiken, SC
Racecraft Inc.-Madison Lake, MN
Smith & Company-Richmond, VA
Richmond Dragway-Sandston, VA
QuickTime Motorsports-Vicksburg, MS
Cutting-Edge Hydrographics-Orange Park, FL
Hyperaktive Performance Solutions-Antioch, IL
Precision Racing Technologies-Virginia Beach, VA
EXSSIVE is offline   Reply With Quote
Old 04-28-2012, 07:46 PM   #4
SSOCOBRA
SSOCOBRA's Avatar
I take them apart , clean with acetone and spray both sides with copper spray
SSOCOBRA is offline   Reply With Quote
Old 04-28-2012, 07:48 PM   #5
8 second renegade
8 second renegade's Avatar
I install them dry,I haven't had a problem yet. I ran copper and they leaked all the time..
Kurgan Motorsports
Vortech Superchargers
BES race engines
Pro Formance Transmissions
Dynamic converters
8 second renegade is offline   Reply With Quote
Old 04-28-2012, 07:49 PM   #6
Skunkworkx
Skunkworkx's Avatar
Copper spray....unless its a fresh build with the proper RMS surface for the MLS gasket you're using.
68 Camaro LSx
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.... N/A
Skunkworkx is offline   Reply With Quote
Old 04-28-2012, 07:53 PM   #7
Devourment138
Devourment138's Avatar
more importantly doesn't the surface/s have to be finished properly?
Devourment138 is offline   Reply With Quote
Old 04-28-2012, 08:10 PM   #8
Honk if parts fall off
Drag Week Survivor
I been using copper spray on them since 2004, i've never had a problem.
Honk if parts fall off is offline   Reply With Quote
Old 04-28-2012, 08:11 PM   #9
Motoimpaired
It's a new motor and the block surface is fresh and correct but I'm using used AFR heads. I love this place for the quick responses, but each response is mixed. Guess I will wait a few more mi.tues for more responses and just go with the majority...
Old 04-28-2012, 08:26 PM   #10
jpwalt1987
jpwalt1987's Avatar
I take them apart , clean them and spray with copper coat.
jpwalt1987 is offline   Reply With Quote
Old 04-28-2012, 08:31 PM   #11
dino17
TD 3550
dino17's Avatar
I always hit em with Copper Coat along with adding 2 GM sealant tabs (Ground to Powder)
When filling the cooling system.
dino17 is offline   Reply With Quote
Old 04-28-2012, 09:29 PM   #12
ordinary builder
be certain that the RIVET does not hold the gasket from being clamped down as flat as possible...
oftentimes we have to smash the rivet before installation or on some blocks / heads, a little die grinder detail work is needed to gain clearance....
ordinary builder is offline   Reply With Quote
Old 04-28-2012, 09:33 PM   #13
Motoimpaired
When you say take them apart, do you mean you remove the rivets, clean them, spray all of them, and then reuse them?? Just curious for future knowledge.. Not that I hope to take this motor apart to soon..... LOL
Old 04-28-2012, 09:39 PM   #14
Bad00SS
Bad00SS's Avatar
I used some MLS gaskets on my LS1. used them dry. no problems here.
346 cubic inches of straight crawlin junk
Bad00SS is offline   Reply With Quote
Old 04-28-2012, 10:08 PM   #15
TwoFast4Lv
Nitrous Junky
TwoFast4Lv's Avatar
Dry the first time and copper spray after that
Ellis Groo
Speed Secrets.
SSEFI.Com
360-217-8150
18 Degree's topped with Nitro Daves Custom System and enough Juice to see how strong a LTx block is!
I KNOW I can't spell...Get over it!
TwoFast4Lv is offline   Reply With Quote
Resources saved on this page: MySQL 1.02%
