Springfield Armory 1911 EMP -9mm- doesn't like hollow points? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > The Bullet ~ Handguns, Rifles and Shotguns
The Bullet ~ Handguns, Rifles and Shotguns TREE HUGGERS NOT WELCOME!!!
Old 04-22-2012, 10:33 PM   #1
sleeperstyle
angry russian
Default Springfield Armory 1911 EMP -9mm- doesn't like hollow points?
like the title states. it seems to jam up when pulling the slide back and releasing to load the first round or any round i cycle by hand after that. it works "better" with normal ammo.
anybody have one of these, and what should i look for as far as wear and replacement parts. anybody have the problem with hollow points in it also? i bought the gun used, put about 600 round through it and cleaned it afterwards. it is in very good used condition
sleeperstyle is offline   Reply With Quote
Old 04-22-2012, 10:36 PM   #2
mideastbusa
Tony McKellar
mideastbusa's Avatar
Default Re: Springfield Armory 1911 EMP -9mm- doesn't like hollow points?
Have the feed ramp polished,use Powerball for your protection ammo.
BoostFab Fabrication
Handy Racing Engines
Donald J. Lawson Masonry
ΜΟΛΩΝ ΛΑΒΕ
Carrottop to THE FRONT!!!!!
Originally Posted by Drag Radial View Post
Now I understand.........this post says it all. You don't race either do you? That's why you quit racing because you had the same parts as others and couldn't get the bitch to fall out of a tree the two times you had it out. I guess everyone that is faster than you with same parts is a bunch of cheaters, right?
Buy local first! Support your local economy.
mideastbusa is offline   Reply With Quote
Old 04-22-2012, 10:39 PM   #3
99PanozAIV
I have a Calico 9mm carbine with the same problem. The nose of the hollow point catches on the edge of the feed ramp. Ball ammo works fine since there is no edge on the nose of the bullet to catch the feed ramp. Not sure of the fix. I just use ball ammo all the time now.
1999 Panoz AIV roadster, one of 55 made that year
What can be asserted without evidence can be dismissed without evidence -- Hitchens
99PanozAIV is offline   Reply With Quote
Old 04-22-2012, 10:44 PM   #4
sleeperstyle
angry russian
yes the remington 115gr. hollow points are a little more smooth on the edge, it does not like the 124gr. federal hollow points junk ammo.
Old 04-22-2012, 10:46 PM   #5
sleeperstyle
angry russian
i will look into both.. thanks
Old 04-22-2012, 10:51 PM   #6
99PanozAIV
Yeah, me too. I had used Corbon some years back in my Glock but hadn't kept up. I disn't know about the Powerball ammo, should be interesting out of the carbine barrel.
Old 04-23-2012, 01:21 AM   #7
Unslow1
Unslow1's Avatar
My SA 1911 Mil-spec 45 won't feed hollow points either.
Unslow1 is offline   Reply With Quote
Old 04-23-2012, 09:09 AM   #8
SScott
http://www.youtube.com/watch?v=2yahzMTOO34
I use a small sand flap (instead of the eraser method) to start with but I have done it a lot. Just don't get the stones out.
SScott is offline   Reply With Quote
Old 04-23-2012, 11:11 AM   #9
sigman
cynic/realist
sigman's Avatar
Rounded ammo.....powerball, critical defense, Golden Saber, etc.....
“Think of the press as a great keyboard on which the government can play.”
Joseph Goebbels
Logic is the enemy, and the truth is troublesome.
sigman is offline   Reply With Quote
Old 04-24-2012, 10:55 AM   #10
1quik70
1quik70's Avatar
Most 1911 style pistols prefer to cycle the round ball ammo they were designed for. I found the critical defense to cycle flawlessly out of all
My 1911's .45-.380.
70 Nova BBC, TH400 3800 stall, 8.5 posi 10 bolt w/ 4.10 and Moser axles. **SOLD** Bought a business and am currently car-less!!!
1quik70 is offline   Reply With Quote
Old 04-26-2012, 07:39 PM   #11
schufflerbot
schufflerbot's Avatar
1quik70 is correct, the 1911 is a military design and was not intended to ever have hollow points cycled. polish the feed ramp first, if that doesn't work you may have to re-ramp the frame. be careful with this process, however, as too much will ruin the frame and could be dangerous.
...tell your mom i'm really sorry about the bruises.
schufflerbot is offline   Reply With Quote
Old 04-29-2012, 03:34 AM   #12
Tim L
Does the EMP have an aluminum frame? if so you do not want to try polishing the feed ramp if it is part of the frame. the anodizing is pretty thin and could be removed. if the feed ramp is part of the barrel then it won't be a problem.
Tim L is offline   Reply With Quote
Old 04-29-2012, 12:59 PM   #13
2000_SS
2000_SS's Avatar
My EMP doesn't always like Hornady critical defense, never had a single issue with any FMJ's though. I haven't actually tried any other defense rounds yet, need to get on that.
Take a critical defense round and set it next to a Remington fmj, you'll see it's a good 1/16" shorter. A different round with a rounded our longer projectile should resolve the problem. I am going to polish my feed though.....
>>>Bentune Performance & Fabrication<<<
'01 Camaro SS - HKE 454 LSX - T56 - Moser 9" -454LSX & T-56 for sale soon!
2000_SS is offline   Reply With Quote
Old 04-29-2012, 02:14 PM   #14
BTL FED
In Glock I Trust
BTL FED's Avatar
Sell it and buy a Glock.
"We all know UFOs are real. All we need to ask is where are they from."-Dr./Astronaut Edgar Mitchell, 1971
BTL FED is offline   Reply With Quote
Old 04-29-2012, 02:36 PM   #15
sleeperstyle
angry russian
not a glock guy, i like my plastic-less 1911.
the feed ramp is part of the barrel. i have yet to polish it, ill get around to it .. i have standard ammo in there now
Resources saved on this page: MySQL 2.11%
