battery charging problems - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 04-23-2012, 08:28 AM   #16
Monte442
Monte442's Avatar
Default Re: battery charging problems
As far as a charger recommendation,myself and several of my friends have had great luck with the C-Tek 3300.
Monte442 is offline   Reply With Quote
Old 04-23-2012, 06:36 PM   #17
tt69camaro
tt69camaro's Avatar
Thanks Monte442
Ray- I looked at the data log and it shows 13.5 volts during the run.
Drag racing is a sport you need two balls for!
www.forcedpsi.com
9.0:1 conventional headed 509 ci w/ twin 88's
3400# "Street car"= 1.18, 3.13, 4.70 @ 156.8mph
192.8mph in the 1/4 (lifting twice) 29.6#s of balls & boost
tt69camaro is offline   Reply With Quote
Old 04-23-2012, 10:34 PM   #18
RRRAAAYYY2
RRRAAAYYY2's Avatar
Originally Posted by tt69camaro View Post
Thanks Monte442
Something is wrong. Do a voltage drop test on the system. Instructions are on the top of this forum. Alternator to battery, batery to kill, kill to front panel. Do those three first, and see what you get.
Like to thank everyone at YB for the help with the Help a Child Smile Fundraiser. Your efforts were very much appreciated.
If anyone needs to reach me for Tech my home email is raymonddknight@gmail.com or 1-888-214-7774 . Dec 09, 2010
RRRAAAYYY2 is offline   Reply With Quote
Old 04-23-2012, 10:52 PM   #19
MAGNUM
How do you do a voltage drop test? I think I know, but I am not sure.
MAGNUM is offline   Reply With Quote
Old 04-23-2012, 11:19 PM   #20
RRRAAAYYY2
RRRAAAYYY2's Avatar
Thread at the top of the forum. Super easy, but nobody will do it right still, lol.
Old 04-26-2012, 12:49 PM   #21
MAGNUM
I have multimeters & amp probes & still would like to get a detailed explanation or a link to the proper way to do a draw test. ( it isn't in any post that I could find in this thread.) thx
Old 04-26-2012, 01:45 PM   #22
Danny Cabral
Danny Cabral's Avatar
Originally Posted by MAGNUM View Post
...still would like to get a detailed explanation or a link to the proper way to do a draw test.
A voltage drop test or an amperage draw test?
They're not the same test; although both can be performed with a multimeter.
http://www.yellowbullet.com/forum/sh...d.php?t=229395 (voltage drop test)
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Danny Cabral is offline   Reply With Quote
Old 04-27-2012, 12:08 PM   #23
MAGNUM
Thanks.
Resources saved on this page: MySQL 1.10%
