Modular Timing guide pivot/dowel upgrade - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 03-28-2012, 10:13 PM   #1
rtusnake
Default Modular Timing guide pivot/dowel upgrade
I have noticed over the past couple years alot of the higher hp modular guys was starting to have problem with the stock timing dowels breaking in the teskid block. Most of them seem to come from spinning and catching traction, putting more of a strain on the timing components. We noticed there is a good bit more material in the block to accept a larger stud. We decided to step the stud size up to a M8x1.25 over the stock 6mm stud. Install is pretty straight forward, just redrilling and tapping the hole for the new stud. These will also work in the wap and iron blocks. Haven't seen as many failures in the iron blocks though. I haven't had my hands on a boss block but they should work if it uses a similar size stock dowel.This a pretty simple part to make if you know someone with a machine shop. We also made several sets if anyone needs some
The problem
New stud vs the old
Few extras
rtusnake is offline   Reply With Quote
Old 03-28-2012, 10:30 PM   #2
OJs99Cobra
Default Re: Modular Timing guide pivot/dowel upgrade
never had an issue with the stocker? have a feeling whatever is causing that to occur will bust the bigger one as well. I think it would be more beneficial to modify tensioner so that it is not able to bottom out with change in oil pressure, which I believe is the issue when street driving and going on/off wide open throttle frequently.
Thanks to local support:
Phase II Machine
Wagon Wheel Performance
Linear Performance
IRT
MCP
HPPowdercoating
OJs99Cobra is offline   Reply With Quote
Old 03-28-2012, 10:35 PM   #3
rtusnake
Seems to be more of the higher powered street cars. First pic has happened to the same guy twice
Old 03-28-2012, 10:38 PM   #4
OJs99Cobra
on/off throttle......tires break loose=off throttle, stab throttle when recover, repeat....
Phase II Machine
Linear Performance
IRT
MCP
HPPowdercoating
Old 03-30-2012, 04:42 PM   #5
MMR Mustang
1-877-MOD-POWR
MMR Mustang's Avatar
Nice product, we have been making them for some time. Another easier option is to use the tap-in dowel from the Iron block, you simply drill the hole (about .001 tho undersize on the hole for a nice press fit.) and tap the new dowel in with a hammer -no more threading etc. The best part is they cant come out because the timing cover wont let them.
MMR
www.modularmotorsportsracing.com - 2014 NMCA Champions WORLD 5.4 DOHC RECORD HOLDER 5.95 / 246.89 - Worlds Fastest Modular Mustang (non tube chassis) 6.75 @ 219.74- 5.4 29 x 10.5W , Worlds Fastest 5.0 Coyote 4.39/178 1/8 and 6.75 1/4 Worlds Fastest Modular on 10.5's - 4.00 @ 188.8 1-877-MOD-POWR.
MMR Mustang is offline   Reply With Quote
Old 03-30-2012, 05:13 PM   #6
rtusnake
When you install the dowels, do make them larger are just use the stock press in dowels for the iron blocks?
Old 04-02-2012, 01:16 PM   #7
blackonblacksls
MMR
I have broke even these! But have moved to larger than stock tool steel dowels.
blackonblacksls is offline   Reply With Quote
Old 04-02-2012, 01:17 PM   #8
blackonblacksls
Your a smart man. 100 Street miles do more damage than 1000 track passes with these mod motor timing sets.
Old 06-03-2014, 03:57 PM   #9
Bullitt5094
Do you still have these upgraded pivots available?
Bullitt5094 is offline   Reply With Quote
Resources saved on this page: MySQL 1.11%
