***Roll Cage FAQ's*** - Page 12 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 01-25-2012, 10:26 PM   #166
72BBC
72BBC's Avatar
Default Re: ***Roll Cage FAQ's***
Went and picked up the tubing this morning, crawled into what was once the backseat like a Cirque De Solie acrobat and figured I could get the torch up enough on one side to feed it from the other side and actually filled it all in anyway.
Should pass no issue now.
I hope
72BBC is offline   Reply With Quote
Old 01-29-2012, 11:03 AM   #167
racecar77
racecar77's Avatar
My question was asked by someone else in here but never really answered. Converting a 6 point moly to a 10 point. My existing door bars are the correct height and welded to the frame rail. Can the new A-post bars come down and be welded to the frame right in front of the existing door bar? Or I could actually notch the A-post bar and contact the door bar and frame together. Is this a legal connection or do I have to cut the door bar out and re-connect it to the A-post bar after it's in? Thanks for the help, hope I explained this clearly.
"You are literally too stupid to insult."
racecar77 is offline   Reply With Quote
Old 01-29-2012, 11:10 PM   #168
smallblocken
smallblocken's Avatar
I have a ? i'm in the market to put a cage in a 87 s10 and was looking to see if anyone here has anyone in mind to do same near NC please advise thanks. looking to run 5.50 to 60 on spray
smallblocken is offline   Reply With Quote
Old 02-15-2012, 08:00 PM   #169
Steedafied
Steedafied's Avatar
I outlined the bar in question in red in the picture below. I am converting a 10pt to 25.5 and was wondering the specs of this bar.
What are the rulings for this bar? does it have a certain location it needs to be in comparison to the driver? I see some really close to the main hoop and some are farther out, just wondering the story on this one, and no I won't buy the book.
Thanks
Steedafied is offline   Reply With Quote
Old 02-16-2012, 12:01 AM   #170
overkillrc
7.86 @ 8800DA 3365lb 275s
overkillrc's Avatar
Thanks
Why won't you buy the book?
Justin Kill
Overkill Race Cars 970-581-8134
Loveland, CO
www.overkillracecars.com
H-body control arms and parts
http://www.overkillracecars.com/Products.html
overkillrc is offline   Reply With Quote
Old 02-16-2012, 12:57 AM   #171
mikeyfrombc
mikeyfrombc's Avatar
Thanks
don,t be a cheap ass fuck buy the damn book ,the rest of us did ,it,s $35
Demon Precision Products
mikeyfrombc is offline   Reply With Quote
Old 02-16-2012, 01:02 AM   #172
bird1777
bird1777's Avatar
Took the words right out of my mouth. Buy the book, it's well worth the $35. .
I Call As I See It,
Byrdshyt
bird1777 is offline   Reply With Quote
Old 02-16-2012, 01:05 AM   #173
JBoone
JBoone's Avatar
I think there is a minumn But i have seen cars cert as close as 8 inches away from the main hoop. I can look tomarrow. That maybe a tech mans call that puts the sticker on
JBoone is offline   Reply With Quote
Old 02-16-2012, 11:53 AM   #174
Steedafied
Steedafied's Avatar
Cool thank you I do appreciate it.
Old 02-16-2012, 11:54 AM   #175
Steedafied
Steedafied's Avatar
Because I don't want the book.
Old 02-16-2012, 04:01 PM   #176
MichaelP
MichaelP's Avatar
I still don't get why you don't want to get the book, but presumably you are working with someone on the chassis that has it?
As far as the position of that bar, this was discussed recently in this thread:
http://www.yellowbullet.com/forum/sh...d.php?t=167144 - starting at post #937
It is clear to me that even with the allowance for only the "forehead" part of the helmet, many cars do not pass this rule. Next time you are watching NHRA Pro Stock on TV look how far back their FC cage bars are.
1999 Chevy Silverado Pro Stock Diesel - under construction. LBZ Duramax, GT4202R over GT5541R, Sponsored by ISSPRO and Chris Alston's Chassisworks
1973 Vega Super-Gas car, 481" BBC
1974 Vega bracket car, 350" SBC
1973 Pontiac T/A 455
1992 GMC Typhoon
1973 Chevy Blazer with Pontiac 400
1995 F350 Crew Cab Dually - intake, exhaust, chip, injectors
2000 VW Jetta TDI - Kerma tuning, Der Chimera clutch
MichaelP is offline   Reply With Quote
Old 02-17-2012, 10:46 AM   #177
Steedafied
Steedafied's Avatar
Cool thanks for the link/info, that is how I thought it was supposed to be but as you said from all the cars I've seen around told me otherwise!
"When required, the Forward Outer Funny Car Cage Bar (#40A) and the Forward Inner Funny Car Cage Hoop (#41B) must be fully forward of the driver’s helmet."
Old 04-12-2012, 07:27 PM   #178
03ramit1
Ok installing a MS cage and plan on getting a 8.50 cert, buy was wondering if I can TIG the visible welds and mig the hard to reach places. I would rather look at a TIG weld than a mig weld, but want to make sure it will pass. Otherwise I'll just mig the whole thing. Thanks.
A wise man once said you need a pistol, rifle and a shotgun for every daughter you have.
I have 4 girls, looks like I need about 6 more kids......
03ramit1 is offline   Reply With Quote
Old 04-12-2012, 09:06 PM   #179
Pitbull
Trouble Maker, So Im told
Pitbull's Avatar
Thanks
Must be in front of ANY portion of drivers helmet .
Dealer for :
Carnivore Performance
Team Z Suspension
Probe Industries
PA Racing Suspension
Dynamic Racing Transmissions
Procharger
Trick Flow
Product Engineering
R2C performance Products.
SCT
Now a dealer for Wild Rides
True Street Sponsor 2006
Proud Sponsor of OSCA Pro Stock class 2009
11.90 Index Sponsor 2010
Pitbull is offline   Reply With Quote
Old 04-13-2012, 08:05 PM   #180
Defender Chassis
Defender Chassis's Avatar
Yes
Defender Chassis is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
