Question on converter flushing - Yellow Bullet Forums
Old 01-22-2012, 03:32 PM   #1
MrFord
MrFord's Avatar
Default Question on converter flushing
Hi guys, I have one of my old TCI converters that has been sitting in a box for 20 years with a sock stuffed into it to keep out the squirrels. Sooooo, needless to say it should be flushed before I put it back into use. How do I do that, or if it goes to a shop, how should THEY do it?
MrFord is offline   Reply With Quote
Old 01-22-2012, 05:37 PM   #2
Crosley
Default Re: Question on converter flushing
Converter technology has changed a great deal in 20 years... I would have the converter opened and serviced for your current combination. Beyond that, most converter shops would cut the unit open for inspection and cleaning
If you find yourself in a ditch... let up on the throttle and down shift
Crosley is offline   Reply With Quote
Old 01-22-2012, 05:52 PM   #3
Packersfan
Packersfan's Avatar
You'll never get all the small metallic debris out of a converter by flushing it.
Packersfan is offline   Reply With Quote
Old 01-22-2012, 06:06 PM   #4
Hutch's Avatar
It can be drilled and flushed and if done properly it will be nice and clean when its done. If you are just looking to get the old oil out of it , thats what a good flush will do. If the converter was removed from a dirty trans or one that has metallic debris , you may want to send it out and have it cut open and cleaned properly.
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 01-22-2012, 06:57 PM   #5
MrFord
MrFord's Avatar
Thanks for the replies! I believe the converter came off a good trans, but that was a long time ago to recall. What is a fair ballpark price to open and inspect a converter?
Old 01-22-2012, 07:41 PM   #6
Hutch's Avatar
I think normally 250.00 is where it starts with most companies to cut clean and reweld/balance.
www.hutchtrans.com
519-453-4318
Old 01-23-2012, 02:44 PM   #7
JWoods5150
Hutch, where is the best spot to drill a coverter. I drill one a long time ago when I was young, stupid and lucky, but if I tried it now I would definately screw something up internally.
JWoods5150 is offline   Reply With Quote
Old 02-09-2012, 11:21 AM   #8
DirtyD0g
If there is nothing wrong with it $75 for 9.5-12 inch units. Smaller units and larger units are more. Anything more than that without adding parts or hub changing,etc...is just a scam. It takes about an hour to do.
If you don't know the converter inside don't drill it without opening it.
Flushing just stirs the stuff around there are too many places for it to get stuck I don't suggest it. I have seen flushed out converters cut open the next day over a problem and the transmission was clean. The gunk builds up on the outside a 1/4 thick. Fresh fluid breaks it down and you have fine metal crap floating around inside there.
Alan
DirtyD0g is offline   Reply With Quote
Old 02-09-2012, 01:43 PM   #9
protobuild
protobuild's Avatar
There was a local shop that would tap a drain fitting and pressure flush a converter while it slowly turned the internals. They did one for me several years ago, Never had any problems out of it.
Old Crank Racing.
protobuild is offline   Reply With Quote
Old 02-09-2012, 06:51 PM   #10
Taff
Taff's Avatar
Put a remote oil filter setup in the oil cooler line,this will catch any debris from the converter before it gets to the 'box,you can then change the filter after a short time or even remove the remote stup after a while if you wanted to. I've always done this if I buy a secondhand converter,a remote filter head,filter.fittings and short lines will cost less than a flush out and you can reuse the filter setup over and over.
Taff is offline   Reply With Quote
Old 02-09-2012, 09:23 PM   #11
Detroit Gearbox
Detroit Gearbox's Avatar
Ive had converters Loaded with metal, flushed them then cut them open. I was shocked and surprised to see they were spotless.
Detroit Gearbox 586-777-4444
21279 Groesbeck Highway, Warren Michigan 48089
Detroit Gearbox is offline   Reply With Quote
Old 02-10-2012, 12:49 AM   #12
Hutch's Avatar
Alan
So cutting , cleaning , rewelding , rebalancing a converter for more than 75 bucks is a scam? Unreal.
www.hutchtrans.com
519-453-4318
Old 03-05-2012, 05:04 PM   #13
DirtyD0g
I would say charging $300 for an hour of labor is, I have this policy that I try to treat people the way I want to be treated so I charge what I consider is fair, $300 is definately nowhere near fair. It usually forces people to buy a new converter. This is why the market is flooded with used dirt cheap useless converters. People see a converter they can get for $450 or figure it will cost them $300 to repair the one they have and they usually buy new. The $450 converters aren't worth the time to install in any race application. Most of them are so inefficient and cheaply built they raise transmission temperatures so bad that people think their transmission went bad.
Alan
Resources saved on this page: MySQL 1.04%
