Coilover brackets and squarewave 175 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 06-07-2011, 06:28 PM   #1
Foxy313
Foxy313's Avatar
Default Coilover brackets and squarewave 175
Tacked coilover brackets on housing with Hobart 140 mig, can I safely tig them with my Lincoln Squarewave 175 even tho not enough amps if follow the .001/amp rule....can I do it safely, suggestions for the diy'er??
Foxy313 is offline   Reply With Quote
Old 06-07-2011, 06:55 PM   #2
Real McCoy
Real McCoy's Avatar
Default Re: Coilover brackets and squarewave 175
That 175 Lincoln can easily weld the brackets to a housing. You should have plenty of amps available.
Real McCoy is offline   Reply With Quote
Old 06-07-2011, 07:18 PM   #3
Foxy313
Foxy313's Avatar
Thanks McCoy, should i do alternating side stitches to minimize distortion, as housing ends are alrdy in place, thx.
Old 06-07-2011, 07:47 PM   #4
CurleysRacecars
Are they simple little brackets/tabs, or do the go half way around the axle tube or something? The 175 is plenty of machine for a bracket as McCoy mentioned. If it is a small tab, I wouldnt worry too much about overheating or distortion. Should be fine...
Kyle Curley
Curleys Racecars & Components
(916)-397-3465
www.curleysracecars.com
DEALER FOR:
Kinetic Engineering
Viking Performance
AFCO
Dynatech Headers
Call or message for the best pricing!
CurleysRacecars is offline   Reply With Quote
Old 06-07-2011, 07:59 PM   #5
Foxy313
Foxy313's Avatar
They are the team z coilover brackets, 1/4 thick
Old 06-08-2011, 05:24 PM   #6
Gary Anderson
FUCKING ASSHOLE SINCE '61
If your worried about warpage wrap a moist towel or rag
around the tubing on both sides of your weld.
Cheap and easy heat sink!!
I do this all the time.
That 175 will work well!!
Your Pal, Gary
Gary Anderson is offline   Reply With Quote
Resources saved on this page: MySQL 2.33%
