nos wiring components - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 10-28-2005, 08:40 AM   #1
69yenko
Default nos wiring components
Mike, I am installing a single stage fogger and have a few questions about recommended parts and wiring. Can I use p/n MSD-8960 DPST 30amp relay for the fuel and nos solenoids with the fuel on one side and the nos on the other. Also do you use fusible links or fuse holders between relay and solenoids. And finally, what size wire is recommended for load wire from power source to relay to solenoid, and trigger wire from switch to relay. Thanks Troy
69yenko is offline   Reply With Quote
Old 10-28-2005, 12:32 PM   #2
MichiganSkip
Thread Killer
MichiganSkip's Avatar
I sent you a PM
1144
MichiganSkip is offline   Reply With Quote
Old 10-28-2005, 06:06 PM   #3
Sparky
Sparky's Avatar
Troy,
The Relay you listed would work fine for your application, you could also get away with running the MSD-8961. You should fuse either the Power side of the relay (Pin 30) or the output side to the Solenoids (Pin 87).
As for Wire size to the solenoids, bigger is always better. Something in the 14 to 12 Gauge wire size should more then get the job done. On the trigger side of the relay, 18 gauge wire works very well.
I hope this helps,
Sparky
Sparky is offline   Reply With Quote
Old 10-28-2005, 06:53 PM   #4
69yenko
Thanks for the info.
Resources saved on this page: MySQL 2.22%
