mounting Vortech to frame - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 01-08-2010, 11:39 AM   #1
10sec.et
Default mounting Vortech to frame
i have a 69 A body and will be running front and mid engine plates. other than frame flex, is there any reason i couldnt or shouldnt mount my Vortech to the frame ? its for an Olds so i have to fab brackets no matter where i put it and this location would certainly simplify things.
10sec.et is offline   Reply With Quote
Old 01-08-2010, 04:15 PM   #2
bigblockbill-NM
bigblockbill-NM's Avatar
Default Re: mounting Vortech to frame
Guess I can not make a good argument on why not to do it.
'56 Ford, 400 SBC, Blown Injected Alky (Sold)
'70 Chevelle street/strip car, 350 SBC, 6-71, E-85 MFI, in the works.
bigblockbill-NM is offline   Reply With Quote
Old 01-08-2010, 08:54 PM   #3
rtj
rtj's Avatar
Probably easier to align if you go off the engine. Just my 2cents.
rtj is offline   Reply With Quote
Old 01-09-2010, 12:12 AM   #4
10sec.et
exactly what i was thinking.
good point. the bolt holes in the heads and front of the block were engineered to mount "accessories" and would be the best mounting surface perpendicular to the crankshaft.
i need to take some more measurements............
Resources saved on this page: MySQL 1.18%
