Switching over to E85 Holley EFI - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 07-17-2013, 08:04 PM   #1
samdogmx
samdogmx's Avatar
Default Switching over to E85 Holley EFI
I'm pretty sure I know what all needs to be changed but just want to double check, with Holley efi system currently running on 93 to switch over to E85 I need to
1 - add 35% to base fuel table
2 - add 35% to AE vs TPS rate of change and AE vs MAP rate of change
3 - add 35% to Cranking fuel
4 - change target afrs to 10.8 - 11ish under boost
Is that all?
what is a acceptable afr for idle? 12.5-13?
SAM
1979 Camaro
TT LSX
samdogmx is offline   Reply With Quote
Old 07-17-2013, 08:58 PM   #2
turbo6man
turbo6man's Avatar
Default Re: Switching over to E85 Holley EFI
I started running my car with E85 so I cannot answer the setup questions. But I can tell you I target 10.8 AFR using the gas scale at WOT. I had problems with the plugs misfiring at an idle with them in the 12.8 to 13.2 AFR range. I idle at 14.0 to 14.3 now and have not had any idle misfiring issues.
1963 chevyII: 410" dart ls built by modern speed and TFS Frankenstein cathedral heads. Billet atomizer 225 inj 1/2" fuel line(3/8's return) with dual Magnafuel 750 pumps E85 GTX5533-91 turbo Liquid intercooler 5" exh. Four link and ford 9" with 3.25 gear ratio and mini tub with 28X10.50-15 radial drag slicks Checkered racing front clip with Alston coil overs. best time 5.20/8.19@136.9/167 MPH with 24 to 25 psi boost ramped in and 1.30 60'
turbo6man is offline   Reply With Quote
Old 07-18-2013, 03:51 PM   #3
69TA
69TA's Avatar
Is that all?
NO. You DO NOT need to add anything to any table - only exception maybe crank fuel.
You should simply let closed loop and LEARN do the adjustments necessary to the fuel map. Every engine is different. Som like 15% some like 30% more volume than gas.
10.8-11ish under boost seems awefully rich to me. I would start with 11.5 and go from there.
Idle around 14.0 or as lean as your engine likes. A lean idle can never hurt an Engine.
69TA is offline   Reply With Quote
Old 07-18-2013, 04:30 PM   #4
turbo6man
turbo6man's Avatar
My opinion would be to add the 30% Fuel to the map(above idle), If it is too rich you can let the closed loop learn subtract fuel. Alot of people have said you can make more power at 11.5 but my experience has been that reliable power can be made at 10.8 AFR(Gas scale on E85). I ran a Buick v6 @ 24 to 30psi boost for two years with alot of track passes and stock LQ4 at 15psi and now the built lq4 at 19psi. All with a target of 10.8 and have never hurt any of them. I would say that you are correct and I am probably to rich and leaving some more power on the table if I was to lean it out. The true answer I believe would be for me to get my tune rock solid at 10.8 then start reading the plugs and leaning it out till it runs the best because every motor likes afr alittle different but 10.8 has worked Very reliably for me and ran et's to my expectations.
Old 07-18-2013, 04:34 PM   #5
Danny Cabral
Danny Cabral's Avatar
Holley EFI & E85:
http://www.yellowbullet.com/forum/sh...85&postcount=2
http://www.yellowbullet.com/forum/sh...d.php?t=480023
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Danny Cabral is offline   Reply With Quote
Old 07-19-2013, 05:31 AM   #6
Brillko
Change target AFR and your fuel mao will Change. Start out with a Little more CL / Learn and be nice to it. For Cold starts i usually add up to 400% more fuel but subracts it almost imediatly. E85 fires on the pump fuel in it when its Cold.
http://www.brillko.com
Brillko Engineering
Brillko is offline   Reply With Quote
Resources saved on this page: MySQL 2.27%
