Trick Titanium bellhousings - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Pro Modified
Pro Modified Talk about Pro-Mod racing with censorship...
Old 12-20-2012, 05:07 PM   #1
T1MUG
T1MUG's Avatar
Default Trick Titanium bellhousings
So whats the fix after you have a new legal liner fitted up to the flange to pass tech.
Now my 168 tooth flywheel and clutch assembly won't fit inside the can because the new liner prevents this .
Anybody else in this same scenario ?
1.08 - 60ft
3.08 - 330ft
4.78 - 1/8th
7.48 / 181mph
T1MUG is offline   Reply With Quote
Old 12-20-2012, 05:47 PM   #2
markstang
markstang's Avatar
Default Re: Trick Titanium bellhousings
smaller flywheel & move the starter unless you can trim back the liner.
markstang is offline   Reply With Quote
Old 12-20-2012, 06:31 PM   #3
chris bozic
chris bozic's Avatar
They should have called before starting any work, to confirm your application (flywheel size) and that you were aware of the new liner requirement and additional cost. I run a 142 tooth flywheel so it and the starter fit within the single 0.078 thick liner. Initially they called and told me that I needed two 0.050 thick liners for an additional $200 each.
Chris
chris bozic is offline   Reply With Quote
Old 12-20-2012, 07:03 PM   #4
Dan Ellis
Dan Ellis's Avatar
We used a flywheel and a starter from ATI.Products.(for an auto trans set up)The flywheel is smaller in dia. And has larger teeth.They make a starter that fits this assembly.
Dan Ellis is offline   Reply With Quote
Old 12-20-2012, 07:21 PM   #5
largeeng
largeeng's Avatar
We have this problem as well Tim. Was over at Andy's last week and he showed us his own flywheel (Ram I think) that he has installed a smaller ring gear on (166 teeth?) to clear the liner. Give him a call as it looks quite straight forward.
We bought Graham's leanders bros clutches and they look tricky to adapt to the new rules ie expensive
Steve Large
largeeng is offline   Reply With Quote
Old 12-21-2012, 09:12 AM   #6
seanss454
seanss454's Avatar
164 tooth flywheel. Expensive fix for many.
seanss454 is offline   Reply With Quote
Old 12-21-2012, 04:38 PM   #7
T1MUG
T1MUG's Avatar
Who makes these 164 tooth flywheels and do you have to get a different starter or can you alter existing starters.
I have a Tilton starter.
Getting the liner updated is no problem over here as we have a Trick Titanium UK dealer who is licenced to carry out alterations/repairs/updates and SFI recertification.
1.08 - 60ft
3.08 - 330ft
4.78 - 1/8th
7.48 / 181mph
Old 12-23-2012, 02:09 PM   #8
Wicked Fast
Wicked Fast's Avatar
So how did trick titanium get away with illegal cans and liners for so long? And are they offering new FREE LEGAL cans to all those they screwed on the illegal ones?
Wicked Fast is offline   Reply With Quote
Old 12-24-2012, 04:47 PM   #9
T1MUG
T1MUG's Avatar
Everyones been screwed over - been illegal for a long time.
Now it's been pointed out to them they should be replacing everyones liner for free to bring it up to SFI spec like it should have been when they sold it to us in the first place.
1.08 - 60ft
3.08 - 330ft
4.78 - 1/8th
7.48 / 181mph
Old 12-25-2012, 12:18 AM   #10
FlyinOhioan
FlyinOhioan's Avatar
Any mfg. who has sold a can that is not within the spec they claimed it to be should be fixing the cans for free including a new tag . Maybe these mfg's should have their SFI status removed for selling bogus products .
FlyinOhioan is offline   Reply With Quote
Old 12-25-2012, 03:16 AM   #11
Injected65
Injected65's Avatar
Who said anything about illegal bellhousings? The SFI spec was modified on August 15, 2012. The word I was given was that all new bells had to have the liner to the flange to meet the spec and all used bells were ok as is until the end of the current cert where they then had to have the liners extended to be recerted.
C & B Motorsports - www.candbmotorsports.com
Innovators West - www.innovatorswest.com
Injected65 is offline   Reply With Quote
Old 12-25-2012, 12:54 PM   #12
cmag
Pretty sure Aug 15 was just a clarification of what was required to meet 6.3.
cmag is offline   Reply With Quote
Old 12-25-2012, 01:33 PM   #13
Jim Wiens
Jim Wiens's Avatar
Heard lot of rumors why the Ti bellhousing failed in 2006 that caused the fatality Most said there were missing bolts on the bottom side is this true ?? Have there been any failures with all of the recommended bolts being in place???
Jim Wiens race cars professional race car construction,Billet cnc components,turbo EFI installation, Block and Cylinder head repair
Nixa Missouri
Mr Harry Hruska
Precision Turbo & Engine
Joe Oplawski Hyperaktive
Tommy Faust TF PERFORMANCE CLUTCHES
Jim Wiens is offline   Reply With Quote
Old 12-25-2012, 03:42 PM   #14
T1MUG
T1MUG's Avatar
I heard a rumor that there were missing bolts on the can but don't know this for certain.
But I did witness the guy on the spectator bank with a hole in his chest bleeding out quickly - died on his way to hospital.
1.08 - 60ft
3.08 - 330ft
4.78 - 1/8th
7.48 / 181mph
Resources saved on this page: MySQL 1.03%
